Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
help me hook up arduino joystick to ez-b to control servo
Help Me Hook Up Arduino Joystick To Ez-B To Control Servo
i have a joystick, it looks like a ps3 or something, its for arduino boards. it has 3 connectors on it, each has a 3-wire attached. (9 wires total)
connector 1 is blue wire, black wire, red wire and labeled (S, GND X, VCC) connector 2 is same, blue, black, and red wires labeled (S, GND Y, VCC) connector 3 is green wire, red wire, and black wire labeled (D, VCC Z R1, GND)
WHERE DO I connect into the ARC with these 3 connectors, also do i need to open anything in the software to tell it what to do? thanks TJ
i added closed captions! so you can read what i say for hearing impaired or if you can not understand my stupid kentucky hick accent!
i also provide a cc service where i will add words to your favorite videos, for a low cost. thanks thegoodrobot atyahoodotcom
#17
I see what the issue is now. I didn't let you know that my hardware does work very well with the Eazy B . It actually is F'N awesome when it comes to buttons and four pots. I love my EZ-B. I added four pot to four servos and it worked great! I even controlled 16 different scripts for each push buttons I used with the Endurance-RC kit. It really compliments your hardware. Their joystick uses the same chip as the EZ , almost look and acts like the Ez B but your software way better and they only allow inputs (looked at the schematics). Best of all, no drivers required windows just picks it up and it works with all games. All! Its super awesome and I have been using them since 2008.
My issue is I need to know how to use more than four pots. Buttons work great. I'm sorry for using that crappy Arduino video/analogies but it was the closes thing I could find at the time. I repeat. Your hardware is very compatible. And I plan on doing a video soon as I get done with my project.
The issue I have is the software limitations. I need to know if I can get your joystick software to detect more pots. Preferable one for every Digital out put via software. Thank for your help and sorry about the confusion. I love my EZ-B and convinced my friends to buy one. Can you please add this functionality or let me know what I'm doing wrong? Also that video you gave me helped outlot I used it soon as I got my EZ-B Programed. Thats how I got 16 buttons working. I just wish that we could some how program more X and Y movments with pots as easily as I did when I pasted scripts for my 16 buttons I add just like you showed in the video. I only saw green and blue dots. Is it a way to make more XY dots pop up or a just add another joystick window or something for the other pots.
And @Hoolagen1.... Stop brown nosing and D@#$ riding. I was just asking for help.
Rashad Glover www.RashadGlover.com
#19
How many flex sensors can you use.
#20
no, you sir were coming off like a dick...
