Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Not sure, it's as funny as how it can be explained to you what to check for above but still have the question asked I guess...
Ensure you are running the same version of ARC on both PCs. Ensure you have the same EZ-Bits sync'ed.
I would suggest re-syncing your EZ-Bit library.
However it still stands that the arm can attach to that part 4 different ways. Following the instructions and calibrating correctly will result in a perfectly working robot no matter if the shoulder bit is at 0/180 or 90/270 degrees.
rich
i check the libery.as for the jd brothers they work perfect. i will post video later
thank you
dj
i saw some diff pics and i thought ,whoops this is wrong. averything works great now.
thank you
