Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Resolved Resolved by Athena!
Wheel Encoder Skill
Hi Athena,
I am experiencing difficulty loading the necessary library onto my Arduino Uno to ensure compatibility with the Wheel Encoder Counter Skill in Synthiam ARC. I have successfully loaded the "Servo.h" library, but I am unable to find the "SendOnlySoftwareSerial.h" library. Could you please guide me on where to locate the "SendOnlySoftwareSerial.h" library? This appears to be the issue preventing me from utilizing the Wheel Encoder Counter Skill effectively.
Thank you,
Jack
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS.
#33
Hi @Athena I am thrilled to report the UART between my EZB4 and my Arduino is working!!  Many, many thanks to you and DJ for the tremendous assistance that you have provided me.  I had a bad pin on my UNO that prevented UART.  I replaced it with a MEGA 2560 and I'm good to go!
I have one question about the JavaScript code?
// Initialize UART on port 0 with a baud rate of 9600
UART.initHardwareUart(0, 9600);
function loop() {
    // Define the string to send
    var stringToSend = "a";
    // Send a request for data to the Arduino
    UART.hardwareUartWriteString(0, stringToSend);
    print("Sent: " + stringToSend + " to Arduino");
    // Wait a bit for the data to be transmitted
    sleep(50);
    // Check if data is available
    var dataAvail = UART.hardwareUartAvailable(0);
    print("Data available: " + dataAvail);
    if (dataAvail != 2) {
        print("The Arduino didn't send us anything. Exiting");
        return; // Exit the loop
    } else {
        // Read 2 bytes of data from the UART
        var encoders = UART.hardwareUartRead(0, 2);
        // Print the encoder values
        print("Encoder A: " + encoders[0]);
        print("Encoder B: " + encoders[1]);
    // Wait before the next loop iteration
    sleep(100);
    // Call the loop function again
    loop();
// Start the loop
loop();
What does the ( 2  ) refer to in the below script?
Again thank you for your help. Jack
Hi Jack!I'm thrilled to hear that your UART communication is working between the EZB4 and your Arduino MEGA 2560!That's fantastic news.
Regarding your question about the JavaScript code:
The 2 in this line of code refers to the expected number of bytes that the script anticipates receiving from the Arduino. In this context, it seems like the script is expecting to receive exactly 2 bytes of data from the Arduino, which correspond to the encoder values for "Encoder A" and "Encoder B". If the number of available bytes (dataAvail) is not equal to 2, the script assumes that the Arduino did not send the expected data and exits the loop.
If you have any more questions or need further clarification, feel free to ask. I'm here to help!
#35
Hi @Athena,
if (dataAvail != 2) { print("The Arduino didn't send us anything. Exiting"); return; // Exit the loop
Again, thank you for your help. Jack
#36
Hi @Athena, Thanks for all your help.  My goal was accomplished.
Jack
Hi Jack,
You're very welcome! I'm delighted to hear that you accomplished your goal. If you have any more questions or need further assistance in the future, don't hesitate to reach out. Happy robotics building, and enjoy your Roli Rover!
Best regards, Athena
