Whats The Best SBC Under $300 To Build A DIY Two Wheeled Robot With A RP LIDAR
What is the best single-board computer (SBC) under $300 to build a DIY two-wheeled robot equipped with an RP LIDAR?
I am considering using a Raspberry Pi 5 with Windows 11.
Could you please direct me to any reference wiring diagrams that I can download for a project like this?
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Hector SLAM navigation with NMS pose and obstacle data for room mapping, waypoints, and autonomous obstacle-avoiding routes.
Rplidar by Slamtec
Slamtec Lidar driver for ARC; scans 360° and publishes distance data to NMS for mapping, obstacle avoidance, and navigation.
For building a DIY two-wheeled robot equipped with an RP LIDAR, the Raspberry Pi 5 is an excellent choice, especially if you plan to run Windows 11. The Raspberry Pi 5 offers a good balance of performance, connectivity, and community support, making it suitable for robotics projects.
  1. Raspberry Pi 5:
    • Pros: Affordable, extensive community support, compatible with a wide range of peripherals.
    • Cons: Limited processing power compared to more expensive SBCs.
    • Price: Around $75-$100.
  2. NVIDIA Jetson Nano:
    • Pros: Excellent for AI and machine learning applications, powerful GPU.
    • Cons: Slightly more expensive, higher power consumption.
    • Price: Around $99.
  3. Odroid XU4:
    • Pros: High performance, multiple USB ports, good community support.
    • Cons: Slightly higher power consumption.
    • Price: Around $80.
  4. ASUS Tinker Board:
    • Pros: High performance, good connectivity options.
    • Cons: Less community support compared to Raspberry Pi.
    • Price: Around $60.
Reference Wiring Diagrams
For wiring diagrams and setup instructions, you can refer to the following resources:
  1. Synthiam's Getting Started Guide:
    • How to Make a DIY Robot
    • This guide provides a comprehensive overview of building a robot, including wiring diagrams and setup instructions.
  2. Raspberry Pi Official Documentation:
    • Raspberry Pi GPIO Pinout
    • This documentation provides detailed information on the GPIO pins and how to connect various peripherals.
  3. RP LIDAR Wiring and Setup:
Steps to Build Your Robot
  1. Choose Your SBC: Based on your requirements and budget, choose an SBC like the Raspberry Pi 5.
  2. Install Windows 11: Follow the instructions to install Windows 11 on your Raspberry Pi 5.
  3. Set Up ARC: Install Synthiam ARC on your Raspberry Pi.
  4. Connect RP LIDAR: Follow the wiring diagram provided in the RP LIDAR documentation to connect it to your Raspberry Pi.
  5. Configure Robot Skills: Add and configure the necessary robot skills in ARC, such as MyFplugin, The Better Navigator, and RPLidar(A1).
  6. Build the Robot Chassis: Assemble the two-wheeled robot chassis and connect the motors to the Raspberry Pi GPIO pins.
  7. Test and Calibrate: Test the robot's movement and sensor readings, and calibrate as necessary.
By following these steps and utilizing the provided resources, you should be able to build a functional two-wheeled robot equipped with an RP LIDAR. If you have any specific questions or run into issues, feel free to ask for further assistance!
