Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
South Africa
What Is The Best Base To Start From.
I started my project a weeks ago and first played with all the bits. I started building my actual robot on a RC car of mine and came to the conclusion that the speed seem to be a bit high. :D Seeing that there aren't many Wall-E`s available in SA I need to make another plan. I tend to think tracks are best but which ones can you guys August? There are many models ans types out there and the prices vary as well. I do not want to break the bank but do not want to waste money on something useless. No shop in SA have tracks that I can look at. I have seen some on the net from tamiya etc but it is only photos and they can be deceiving in size and ease of use. If anyone can give advise i will appreciate it.
Are you using an electronic speed controller? If so, you'd be using a modified servo Movement Panel - and you can adjust the speed in the Config option.
Otherwise, if you're using an L298 - then check the tutorial video on how to connect the PWM to control the speed...
Otherwise, have you seen that dude who made the cardboard wall-e? He has some wicked tracks for it! Robot is here: https://synthiam.com/Community/Questions/1271
