Vuzix 2016 Compatibility
I've explored the forums for headset info but the answers are not solid and seem outdated.
Is there an up-to-date list of which headsets are compatible with the EZB and ARC? Thanks
I've contacted vuzix to see if they are still willing to support their newer products with ARC. I'll let you know if they decide to continue:)
"The Vuzix VR Glasses that DJ uses in the Wall-e video are 920VR, which have been discontinued and can be foudn on eBay. The new version are the 1200VR."
I can't tell whether the 1200VR glasses are compatible from this comment. I also chased some instructions down a rabbit hole to find a list of compatible glasses but the information simply looped without conclusion.
did you took the Red or the Blue pill ?
This is my honest opinion, i got curious and i went to vuzix website, i spent some time (wasted) to try to find old iWear devices (920VR, 1200VR).
I could not find any information, then i tried to look for drivers, then for a support forum. I also checked the SDK.
Only smoke... SDK version is 3.6, but no iWearDrv.dll 32 bit version (needed for ARC).
So if you are a user looking for drivers, or support you are doomed. I can't trust their website, i would stay way.
I would remove ARC builtin support, and move the functionality to an external plugin to avoid inquiries.
ZXen,
The only relevant information is the head tracking (X, Y) without any further development you can control two servos.
There are cheaper versions to obtain head tracking. One cheap idea attaching an android phone (with gyro/acc) to a headphone, then broadcast the sensor data.
I'm joking but the information obtained is the same.
What kind of integration/interaction you have in mind ?
I would love it if I could use a phone instead. For example, my iphone 6 has a screen resolution of 1334x750 which is really good.
I simply want:
  1. The vision from the EZB camera to come through in two halves into the eyewear until a stereoscopic ezb camera is released
  2. Enable x,y control of the neck with the accelerometer
  3. It would be great if the phone's mic and headphones worked so I could speak as the robot and listen as the robot.
My carboard VR system cost $35 and slips over the phone. These are common now, and cheap. And probably the best. Wireless, hi res. They just need a strap.
Vuzix responded and are not willing to move forward.
Can you do something with phones?
I found my old vuzix VR920 today while looking for my kinect power supply in "the big box of old electronics". Connected them up and downloaded VR Manager from here https://www.vuzix.com/support/Download
The driver worked and recognized my glasses perfectly. One challenge is the vuzix controller seems to fire off Pitch (head up and down) and Roll (head tilt left or right) and not yaw (Look left and right). Problem is JD doesn't have a roll servo only a Pitch and Yaw servo. Other than that is great and will be perfect for my telepresence bot.
Check the manual for the control. There is information on how to use the glasses. The jd robot has a head, which has two service for horizontal and vertical. You can connect those servos to the Vuzix glasses. Have fun!
All works well and it is actually really cool (although EZ-Robot app is not very happy in VGA resolution :-) If you get bored and want to add 2 more DOF would be great so we can use the 6 DOF available on Vuzix but I am probably one of the few people (Besides you) who have one of these relics laying around (although I am missing one of the ear plugs).
I have a fatshark dominator 3 that can support 3 Axis head tracking as well. These are fairly common with drone pilots so maybe a good HMD to support but does not seem to be a lot of info documented on interfacing with the Trinity module. https://www.youtube.com/watch?v=7pKzOfopCDY
