I need more torque for a robot I am building, I am thinking of using the JX servo PDI-HV2060MG 60KG Metal Gear High Voltage Core Digital servo 1/5Car
Has anyone got a tips OR advice on using larger torque servo. Can it be used with separate power supply etc?
Thanks for any help
Paul
UK based
Any news on the new RGB 8x8 Display units ?
@Will... The servos I have are almost silent... so definitely pretty quiet...
Hi All
Very helpful I have ordered some of the servo versions, 380kg/cm
great power, easy to fit
I will be making 300+ date file 3D (STL and 2D files for laser cutting) available should you be interested (in about four to six mouth, once I have printed and tested each item etc )
thanks paul UK base
Thanks to you all for the help and advice
The large servo is now working etc
HOW do I close the link (mark the question as resolved)
Until the next time, keep building robots !
Paul
Uk based
What are the 300+ 3D and 2D files of? A robot that you are designing or an existing bot that you are modifying and recreating?
I plan on doing something similar to the Omnibot 2000. I found a collection of 3D files done in Rhino of the Omnibot, but they are not ready for 3D printing and lack details like stand-offs for screwing the parts together.
-Sean
I am currently building Large scale HEXAPOD robot with a robotic body set on top of the hexapod base. All based on the EZ Robot kit. 100% of my own design, mostly made by 3D printed parts and LASER cut Aluminum parts combine with easy to buy off the shelf parts It is my attraction to make ALL the design files for 3D printing and Laser cutting, (DWG, DXF and STL files) available, , allowing changes to the design to be made along with a detailed list of ALL the various parts available to anyone interested in building this robot.
It was inspired by my father who always help me as a small boy to design and make all types of objects, and technology, and that was an activity we always shared and thus became my work and hobby
I want this robot to have some artificial intelligence, facial mode and image recognition, as well as speech and some human like coordination and dexterity. And EZ Robot seems like the way to go! The HEART of the robot will be built around your DEVELOPER KIT (I have three kits)
This Large-scale robot mostly made by 3D printed parts and LASER cut aluminum parts combine with easy buy off the shelf parts. The robot will be about 24inch wide and 20+inch tall. The bottom part is based on a Hexapod and the top parts based a robot human. Each part or date files could be edited/changed by the builder giving freedom of design. My files will contain several options for each main body part I am trying to have a basic design with many options. I have made over three hundred parts and I am slowly start to put the robot together.
Man-o-man that sounds amazing!
