the auction ends in an hour or so. currently at 135.00 that's a GREAT price. one of the arms is a little buster, but who cares right?
im at work so I cant add a link but here'st he ebay item number 181564834452
good luck.
Wii Remote
— Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking.
good luck.
Gone now! That was a good buy for somebody. They are as rare as hen's teeth now It looked to be in very good condition too.
Somebody still trying to flog one for $764.99! Item # 390956718265
Lots of overpriced U-Commands on ebay as well. Christmas is coming I suppose.
I just picked up a U command , I will probably measure it and 3d print a custom one.
That's a good price @jstarne1 I paid sround $40 this time last year plus another $40 to get it shipped from US to Australia which was a very fair price for postage as most dealers want double that or just don't ship here.
3D printing will preserve your Wall-E. You'll also be able to custom make the base to suit your servos.
@Tony , I'm considering scaling it up a bit. Making measurements and drawing parts in 123d. Let's say 50 to 60 percent larger than original. I would like to have the room for a standard size servos instead of micro. The size differences may make it stand out, but we will see. Most the Wall-E projects I see look like they are pressed for space. I ordered a walle on ebay a year ago or so and when I received it, I was Jipped into buying a small figurine. So this is the second time around.
Fortunately shipping was only 5 dollars , and it should be quick because they are in the same state.
I know what you mean by "pressed for space" I've already chopped the Ez-B V4 power base down to half height and it's still annoying/frustrating when I have to re-arrange connections. I usually have to take the base off Wall-E. I think removing the whole power base will only help slightly. I have full size servos for the tracks and just two mini (not micro) servos for the arms inside (the neck servos are all outside). The problem I think is the size of the hatch opening. You could probably design a larger opening for easier access. A 60% size increase would be even better again!
Getting a small figurine instead of a U-Command Wall-E would have been a very unpleasant surprise
Just a point for wall-e buyers, there is a wall-e called the interactive wall-e, which is the same shell, but without remote control. There going for cheap.
Interactive wall-e
@ technopro, interactive wall-e looks similar but the body is 2/3 the size. The ultimate walle is the same general size of the u command, but has more detail and a better paint job. Interactive walle is cheaper than u command and ultimate walle is the most expensive.
the ultimate wall-e is 3x the size of the u-command wall-e also has a bunch of more features -arms rotate -hands grip -"eye lids" in the eye casing.
