Resolved Resolved by Athena!
UART byte array communication explained
UART Byte Array Communication Explained
Hi @Athena,
I'm asking about the best way to communicate via UART between an EZB4 (JavaScript running on the EZB) and an Arduino Mega (C++). I'm a beginner and want to keep the implementation simple but reliable. My understanding is that sending a String is not necessary and that sending an array of bytes would be a better approach. I'm using the EZB4 hardware UART functions (UART.hardwareUart*) on the EZB side and Serial3 on the Arduino Mega side.
To clarify the hardware/ARC context: the Arduino Mega is connected to the EZB4 UART (hardware UART lines). The EZB is handling the real-time hardware UART I/O, and this runs inside an ARC project where ARC scripts manage the higher-level logic. The EZB code is a single JavaScript script running on the EZB (built-in ARC/EZB scripting). The Arduino code is standard C++ running on the Mega. This is not using a separate robot skill for the serial link; the UART I/O is performed by the EZB firmware calls from the script.
I have included my C++ (Arduino) TX and RX code and my JavaScript (EZB4) TX/RX code below for your evaluation. Could you rewrite the code to reliably send data using an array-of-bytes format?
Notes:
  • The Arduino C++ TX and RX must be separate sketches (not combined).
  • The EZB4 code runs as a single JavaScript script on the EZB (using built-in ARC/EZB scripting).
  • This is part of an ARC project where the EZB handles the real-time hardware UART and ARC scripts manage higher-level logic.
C++
Data TX
if (run == 1) {
   bufferFlush();
   totalStepsTaken = (abs(combinedStepsTaken));
   delay(50);
   int byte0 = totalStepsTaken & 0xFF;
   int byte1 = (totalStepsTaken >> 8) & 0xFF;
   int byte2 = (totalStepsTaken >> 16) & 0xFF;
   int byte3 = (totalStepsTaken >> 24) & 0xFF;
   Serial3.write('T');  //Header for Total Steps Taken
   // Send the four bytes one by one.
   Serial3.write(byte0);
   Serial3.write(byte1);
   Serial3.write(byte2);
   Serial3.write(byte3);
   Serial.print("Sent   ");
   Serial.println('T');
   Serial.print("Left F+B Steps:  ");
   Serial.println(abs(LeftFrontWheel.currentPosition()) + abs(LeftBackWheel.currentPosition()));
   Serial.print("Right F+B Steps:  ");
   Serial.println(abs(RightFrontWheel.currentPosition()) + abs(RightBackWheel.currentPosition()));
   Serial.print("Sent combinedStepsTaken:  ");
   Serial.println(totalStepsTaken);
   Serial.println("  ");
   delay(100);
C++
Data RX
while ( run == 1) {
if (Serial3.available() >= 1 ) {
     int incomingByte = Serial3.peek(); // do not remove it yet
     // Check if this byte is our STOP command (assume 'x' is the stop command)
    if ( incomingByte == 'm') {
    Serial3.read();
    miss = true;
    actualCourse = desiredCourse;
  if (incomingByte == 'x') {
     // Consume the byte and stop motors
     Serial3.read();
     Serial.print("Received STOP command: ");
     Serial.println('x');
     stopMotors();
     goto Main; // jump out to the Main section
 if ( incomingByte == 'c') {
    Serial3.read();
    Serial.print( "(Received obs scan complete) command  ");
    Serial.println('c');
  if (Serial3.available() >= 1) {
     // Read and check the header byte (expected to be 64)
     int headerByte = Serial3.read();
  if (headerByte == 64) {
     int32_t b0 = Serial3.read();
     int32_t scaledValue = (b0);
     actualCourse = scaledValue;
     Serial.print(" ..............----------------------------  rec'd actualCourse:  ");
     Serial.println( actualCourse,4);
     lastActualCourse = actualCourse;
     initial = true;
     miss = false;
     loopct = 0;
  if (miss == true ) {
     Serial.print( "                                     Received Missed command:  ");
     Serial.println('m');
      actualCourse = lastActualCourse;
    combinedStepsTaken = abs(LeftFrontWheel.currentPosition()) + abs(LeftBackWheel.currentPosition())
    + abs(RightFrontWheel.currentPosition()) + abs(RightBackWheel.currentPosition());
    if (abs(combinedStepsTaken) > combinedStepsDesired) {
    stopMotors();
    goto Main;
    loopct++;
JavaScript Data TX and RX (single script on the EZB)
var lastActualCourse = null;
setVar("$obsDet", 0);
setVar("$missedIR", 0);
setVar("$obsScanEnd", 0);
while(true) {
//Data RX
 if (UART.hardwareUartAvailable(0) >= 5) {  //5
       var header = UART.hardwareUartReadString(0,1);
      if (header == 'D'){
       var desiredCourseScaled = UART.hardwareUartRead(0, 1);
       setVar("$desiredCourse", desiredCourseScaled[0]);
       print("rec'd desiredCourse:  " +  getVar("$desiredCourse")+ "    cyc:  " + getVar("$cycleCount"));
       } else if (header == 'T') {
       print("Header: " + header);
       // read all 4 bytes from uart #0 that we need for this condition into the array tmpRead
       var TSTRead = UART.hardwareUartRead(0, 4);
       // tmpRead[3,2,1,0] are denoted as they were sent 0,1,2,3
       var totalStepsTaken = (( TSTRead[3] << 24) | ( TSTRead[2] << 16) | ( TSTRead[1] << 8) | TSTRead[0]);
       print("totalStepsTaken: " + totalStepsTaken);
       print( "CYC: " + getVar("$cycleCount") + "   $desiredCourse: " + getVar("$desiredCourse") + "   $actualCourse: " + getVar("$actualCourse"));
       sleep(100);
       controlCommand("$IR_1", "PauseOff");
       sleep( 10 );
       controlCommand("IR_STEP", "ScriptStop");
       sleep( 10 );
       controlCommand("NRS_71.8_58_TEST", "ScriptStop");
       sleep( 10 );
       halt();
   // Data TX
        if (getVar("$obsDet") == 1) {
         UART.hardwareUartWrite(0, ['x'.charCodeAt(0)]);
         sleep(5);
         print( "sent to ARDU...obsDet:  " + getVar("$obsDet"));
       print("OBS IR STOP:  " + getVar("$IRADC"));
       if ( getVar("$missedIR") == 1) {
           UART.hardwareUartWrite(0, ['m'.charCodeAt(0)]);
           print("sent to ARDU...missedIR:  " + getVar("$missedIR"));
       if ( getVar("$obsScanEnd") == 1 ) {
           UART.hardwareUartWrite(0, ['c'.charCodeAt(0)]);
           print("sent to ARDU...Scan for obs ended:  " + getVar("$obsScanEnd"));
        if(getVar("$actualCourse") != lastActualCourse) {
        var scaledValue = getVar("$actualCourse");
        //Send as whole number to Arduino:
        var byte0 = scaledValue & 0xFF;
        var header = [64];
        // Combine the header with the 4 bytes and send via UART
        UART.hardwareUartWrite(0, header.concat([byte0]));
       lastActualCourse = getVar("$actualCourse");
       print(" $actualCourse:  " + getVar("$actualCourse"));
        sleep(200);
Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent.
Script by Synthiam
#25
Hi @Athena, Please rewrite the entire ARC script so it’s safer for ARC and won’t drop the EZ-B offline. Thank you. Jack
Absolutely,Jack - the safest fix is to stop sending on every loop iteration and make UART traffic event-driven + rate-limited. That will greatly reduce the chance of the EZ-B dropping offline.
Below is a rewritten single ARC JavaScript script that:
  • initializes globals
  • sends Right Pivot / Left Pivot / Waypoint Data
  • reads Arduino responses
  • sends Actual Bearing only when needed
  • rate-limits UART transmissions
  • avoids NaN / invalid values
  • keeps the loop light so ARC stays stable
Safer Combined ARC UART Script
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_MISSED_IR = 0x02;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_DATA = 0x06;
var CMD_OBS_SCAN_COMPLETE = 0x07;
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
// State
var lastActualBearingSent100 = -1;
var lastWaypointSentTime = 0;
var lastActualBearingSentTime = 0;
var lastRightPivotSentTime = 0;
var lastLeftPivotSentTime = 0;
// Minimum spacing between sends so we don't flood UART
var MIN_SEND_INTERVAL_MS = 100;
// Helpers
function safeParseInt(value, defaultValue) {
    var n = parseInt(value);
    if (isNaN(n)) return defaultValue;
    return n;
function safeParseFloat(value, defaultValue) {
    var n = parseFloat(value);
    return n;
function u16ToBytes(value) {
    value = value & 0xFFFF;
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
function u32ToBytes(value) {
    value = value >>> 0;
    return [
        value & 0xFF,
        (value >> 8) & 0xFF,
        (value >> 16) & 0xFF,
        (value >> 24) & 0xFF
function canSend(lastTime) {
    var now = new Date().getTime();
    return (now - lastTime) >= MIN_SEND_INTERVAL_MS;
function sendPacket(cmd, payload) {
    var packet = [UART_HEADER, cmd].concat(payload);
    UART.hardwareUartWrite(UART_INDEX, packet);
function sendStopMotors() {
    sendPacket(CMD_STOP_MOTORS, []);
function sendMissedIR() {
    sendPacket(CMD_MISSED_IR, []);
function sendActualBearing100(bearing100) {
    sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
function sendRightPivot(steps) {
    sendPacket(CMD_RIGHT_PIVOT, u16ToBytes(steps));
function sendLeftPivot(steps) {
    sendPacket(CMD_LEFT_PIVOT, u16ToBytes(steps));
function sendWaypointDataFromGlobals() {
    var pathTotalDistance = safeParseInt(getVar("$pathTotalDistance", 0), 0);
    var combinedStepsDesired = safeParseInt(getVar("$combinedStepsDesired", 0), 0);
    var oppositeDistance = safeParseInt(getVar("$oppositeDistance", 0), 0);
    var bearingAlignment = safeParseInt(getVar("$bearingAlignment", 0), 0) & 0xFF;
    var reflectorBearing = safeParseFloat(getVar("$reflectorBearing", 0), 0);
    var sensorPrime = safeParseInt(getVar("$sensorPrime", 0), 0) & 0xFF;
    var desiredBearing = safeParseFloat(getVar("$desiredBearing", 0), 0);
    var actualBearing = safeParseFloat(getVar("$actualBearing", 0), 0);
    var trackDir = safeParseInt(getVar("$trackDir", 0), 0) & 0xFF;
    var payload = [];
    payload = payload.concat(u32ToBytes(pathTotalDistance));
    payload = payload.concat(u32ToBytes(combinedStepsDesired));
    payload = payload.concat(u32ToBytes(oppositeDistance));
    payload.push(bearingAlignment);
    payload = payload.concat(u16ToBytes(Math.round(reflectorBearing * 100)));
    payload.push(sensorPrime);
    payload = payload.concat(u16ToBytes(Math.round(desiredBearing * 100)));
    payload = payload.concat(u16ToBytes(Math.round(actualBearing * 100)));
    payload.push(trackDir);
    sendPacket(CMD_WAYPOINT_DATA, payload);
    print("Sent Waypoint Data");
    print("pathTotalDistance=" + pathTotalDistance);
    print("combinedStepsDesired=" + combinedStepsDesired);
    print("oppositeDistance=" + oppositeDistance);
    print("bearingAlignment=" + bearingAlignment);
    print("reflectorBearing=" + reflectorBearing);
    print("sensorPrime=" + sensorPrime);
    print("desiredBearing=" + desiredBearing);
    print("actualBearing=" + actualBearing);
    print("trackDir=" + trackDir);
// Global initialization
function initGlobals() {
    setVar("$rightPivotSteps", 0);
    setVar("$leftPivotSteps", 0);
    setVar("$pathTotalDistance", 120000);
    setVar("$combinedStepsDesired", 84000);
    setVar("$oppositeDistance", 24000);
    setVar("$bearingAlignment", 0); // 0=DA,1=OA
    setVar("$reflectorBearing", 97.00);
    setVar("$sensorPrime", 4);
    setVar("$desiredBearing", 79.35);
    setVar("$actualBearing", 79.00);
    setVar("$trackDir", 0); // 0=FD,1=RD
    setVar("$sendWaypointNow", 0);
    setVar("$rightPivotNow", 0);
    setVar("$leftPivotNow", 0);
    print("UART globals initialized");
// UART RX parsing
function readIncomingPacket() {
    while (UART.hardwareUartAvailable(UART_INDEX) >= 2) {
        var header = UART.hardwareUartRead(UART_INDEX, 1)[0];
        if (header != UART_HEADER) {
            continue;
        var cmd = UART.hardwareUartRead(UART_INDEX, 1)[0];
        if (cmd == RSP_NAV_ACK) {
            print("ARC received NAV ACK");
            continue;
        if (cmd == RSP_TOTAL_STEPS) {
            while (UART.hardwareUartAvailable(UART_INDEX) < 4) {
                sleep(1);
            var data = UART.hardwareUartRead(UART_INDEX, 4);
            var steps = data[0] | (data[1] << 8) | (data[2] << 16) | (data[3] << 24);
            print("Total steps received: " + steps);
            continue;
        if (cmd == RSP_DESIRED_BEARING) {
            while (UART.hardwareUartAvailable(UART_INDEX) < 2) {
                sleep(1);
            var data2 = UART.hardwareUartRead(UART_INDEX, 2);
            var bearing100 = data2[0] | (data2[1] << 8);
            print("Desired bearing received: " + (bearing100 / 100.0));
            continue;
        if (cmd == RSP_OBS_SCAN_REQUEST) {
            print("Arduino requested obstacle scan");
            setVar("$obsScanEnd", 1);
            continue;
        print("Unknown Arduino cmd: " + cmd);
// Main
initGlobals();
while (true) {
    // 1) Handle incoming UART first
    readIncomingPacket();
    // 2) Event-driven outgoing commands
    if (getVar("$obsDet", 0) == 1) {
        sendStopMotors();
        print("Sent STOP MOTORS");
    if (getVar("$missedIR", 0) == 1) {
        sendMissedIR();
        print("Sent MISSED IR");
    if (getVar("$rightPivotNow", 0) == 1 && canSend(lastRightPivotSentTime)) {
        var rightSteps = safeParseInt(getVar("$rightPivotSteps", 0), 0);
        sendRightPivot(rightSteps);
        lastRightPivotSentTime = new Date().getTime();
        print("Sent RIGHT PIVOT: " + rightSteps);
    if (getVar("$leftPivotNow", 0) == 1 && canSend(lastLeftPivotSentTime)) {
        var leftSteps = safeParseInt(getVar("$leftPivotSteps", 0), 0);
        sendLeftPivot(leftSteps);
        lastLeftPivotSentTime = new Date().getTime();
        print("Sent LEFT PIVOT: " + leftSteps);
    if (getVar("$sendWaypointNow", 0) == 1 && canSend(lastWaypointSentTime)) {
        sendWaypointDataFromGlobals();
        lastWaypointSentTime = new Date().getTime();
    // 3) Send actual bearing only when it changes meaningfully and is valid
    var currentActualBearing = safeParseFloat(getVar("$actualBearing", -1), -1);
    if (currentActualBearing >= 0) {
        var currentActualBearing100 = Math.round(currentActualBearing * 100);
        // Only send if changed and rate-limited
        if (currentActualBearing100 != lastActualBearingSent100 && canSend(lastActualBearingSentTime)) {
            sendActualBearing100(currentActualBearing100);
            lastActualBearingSent100 = currentActualBearing100;
            lastActualBearingSentTime = new Date().getTime();
            print("Sent ACTUAL BEARING x100: " + currentActualBearing100);
    sleep(25);
Why this version is safer
1. It does not spam UART every loop
Your previous version could send bearing updates continuously and too fast. This version uses:
  • MIN_SEND_INTERVAL_MS
  • value-change checking
  • a lighter sleep(25)
2. It protects against bad values
If $actualBearing is empty or invalid, it won’t send.
3. It handles TX and RX in a controlled order
It always reads incoming data first, then sends outgoing packets.
4. It uses a consistent numeric format
All bearings are sent as x100 integers, which is much safer than floats.
One important ARC note
If $actualBearing is being updated by another skill very rapidly, that skill may be the real source of the offline issue. In that case, I’d recommend:
  • update $actualBearing only when the value actually changes
  • or store it as a scaled integer like 7935
  • or send it only on a timer, not every sensor poll
Suggested ARC test procedure
  1. Run the script with all send flags at 0
  2. Confirm ARC stays online
  3. Set only:
    setVar("$sendWaypointNow", 1);
  4. Confirm the packet sends
  5. Then test:
    setVar("$rightPivotSteps", 2500);
    setVar("$rightPivotNow", 1);
  6. Then test actual bearing updates slowly
If it still drops offline
Then the likely cause is one of these:
  • UART TX/RX wiring issue
  • Arduino sending malformed packets
  • another ARC script also touching UART
  • $actualBearing is being updated too aggressively elsewhere
  • a packet length mismatch between ARC and Arduino
If you want, I can do the next step and give you a matching Arduino sketch revision that adds a stricter packet parser and confirms the packet lengths before acting on them.
#27
Hi @Athena.  The last posted ARC script does not send any of the variables when they are changed to (1) in the global variable function.  EZB4 consistently drops offline during the process when these variables are changed.  I would like to step back and confirm with you the following objectives and make sure going forward that we keep the code as simple as possible in accomplishing these objectives.  I wonder if incorporating a 'time since last send' unduly complicates matters.
Stated Objectives:
Whole-System UART Flowchart
1) High-level architecture
+-------------------+        UART        +----------------------+
| ARC JavaScript    | <----------------> | Arduino Mega         |
| (runs on EZ-B v4) |                    | (stepper + nav logic) |
         v                                           v
  Reads sensors / variables                  Controls motors
  Decides what to send                       Computes bearings
  Builds packets                             Sends status packets
  Parses Arduino replies                     Parses ARC commands
2) Overall control loop
                         |        START         |
                                   v
                    | ARC and Arduino are powered on |
                                   v
            | ARC JavaScript loop begins running continuously |
                                   v
            | Arduino loop begins running continuously      |
            | RX parser always listens for UART bytes      |
                                   v
                 | Which side has something to send? |
                        v                         v
        | ARC sends command to      |   | Arduino sends response to |
        | Arduino when an event     |   | ARC when a status/event   |
        | happens                    |   | changes                  |
                          v                     v
                 | Receiver parses packet safely     |
                                   v
                     | Receiver performs the action |
                                   v
                 | Optional response back the other   |
                 | way for confirmation/status       |
                                   v
                         |      LOOP AGAIN      |
3) ARC Arduino flowchart
This is the direction for:
STOP
MISSED IR
ACTUAL BEARING
RIGHT PIVOT
LEFT PIVOT
WAYPOINT DATA
OBSTACLE SCAN COMPLETE
[ARC detects event]
        v
[Choose command]
        v
[Convert values to bytes]
        v
[Build packet:
Header + Command + Payload]
        v
[Send packet over UART]
        v
[Arduino RX reads bytes]
        v
[Arduino parser waits for:
Header -> Command -> Payload]
        v
[Arduino decodes packet]
        v
[Arduino updates motion/nav state]
        v
[Arduino may send response back]
4) Arduino ARC flowchart
NAV ACK
TOTAL STEPS TAKEN
DESIRED BEARING UPDATE
OBSTACLE SCAN REQUEST
[Arduino detects internal event]
        v
[Choose response command]
        v
[Convert data to bytes if needed]
        v
[Build packet:
        v
[Send packet over Serial3]
        v
[ARC UART loop sees bytes available]
        v
[ARC reads header]
        v
[ARC reads command]
        v
[ARC reads exact payload length]
        v
[ARC decodes packet]
        v
[ARC prints, logs, or changes state]
5) Example command path: WAYPOINT DATA
This is the best "big" example because it shows the full system working.
ARC decides a new waypoint is ready
        v
ARC builds WPT packet
        v
ARC sends packet to Arduino
        v
Arduino RX parser receives bytes
        v
Arduino recognizes:
Header + WPT command + 23-byte payload
        v
Arduino stores:
distance, steps, bearings, direction
        v
Arduino confirms with NAV ACK
        v
ARC receives NAV ACK
        v
ARC starts the navigation script
        v
Arduino begins RUN = 1 movement logic
6) Example command path: TOTAL STEPS TAKEN
Arduino reaches a condition:
- waypoint complete
- pivot complete
- stop command received
        v
Arduino computes total steps
        v
Arduino builds:
Header + TOTAL STEPS command + 4-byte value
        v
Arduino sends packet to ARC
        v
ARC receives bytes
        v
ARC parser reads packet safely
        v
ARC reconstructs the 32-bit step count
        v
ARC uses the value:
- display
- stop
- transition to next state
7) Example command path: ACTUAL BEARING
ARC gets a new actual bearing value
        v
ARC compares it to previous value
        v
If changed, ARC scales it x100
        v
ARC builds packet:
Header + ACTUAL BEARING + 2-byte value
        v
ARC sends to Arduino
        v
Arduino parses packet
        v
Arduino updates PWM correction logic
        v
Motor correction continues
8) What RUN = 0 and RUN = 1 mean in the system
RUN = 0
This is the setup / alignment / pre-move phase.
ARC may send:
- pivot commands
- waypoint data
- stop
- bearing updates
Arduino may:
- wait for data
- pivot wheels
- confirm with NAV ACK
RUN = 1
This is the forward navigation phase.
Arduino may:
- count steps
- calculate desired bearing
- adjust PWM
- send total steps or desired bearing updates
ARC may:
- monitor status
- send missed IR
- send actual bearing updates
- stop motion if needed
9) The simplest "big picture" summary
ARC decides -> builds packet -> sends UART
Arduino receives -> parses packet -> acts
Arduino decides -> builds packet -> sends UART
ARC receives -> parses packet -> reacts
That is the entire system in one sentence.
10) Does this match your objective?
Based on what you described, yes - this flow supports your objective:
reliable UART communication
ARC as the higher-level controller
Arduino handling stepper/motion timing
clear command separation
one protocol for both directions
room to monitor navigation and course correction
ARC UART SCRIPT
ARC UART Script
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
// Example state
var lastActualBearing = -1;
var lastDesiredBearing = -1;
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
    return [
        value & 0xFF,
function sendActualBearing(bearingDegrees) {
    var bearing100 = Math.round(bearingDegrees * 100);
function sendWaypointData(pathTotalDistance, combinedStepsDesired, oppositeDistance, bearingAlignment, reflectorBearing, sensorPrime, desiredBearing, actualBearing, trackDir) {
    var payload = [];
    payload.push(bearingAlignment & 0xFF);
    payload.push(sensorPrime & 0xFF);
    payload.push(trackDir & 0xFF);
    var available = UART.hardwareUartAvailable(UART_INDEX);
    if (available < 2) return;
    if (header != UART_HEADER) return;
        return;
        if (UART.hardwareUartAvailable(UART_INDEX) < 4) return;
        return;
        if (UART.hardwareUartAvailable(UART_INDEX) < 2) return;
        var bearing = bearing100 / 100.0;
        print("Desired bearing received: " + bearing);
        return;
        return;
while (true) {
    // Layer 1: Event logic
        sendStopMotors();
    if (getVar("$missedIR") == 1) {
        sendMissedIR();
    var currentActualBearing = getVar("$actualBearing", -1);
    if (currentActualBearing != lastActualBearing && currentActualBearing != -1) {
        sendActualBearing(currentActualBearing);
        lastActualBearing = currentActualBearing;
    var currentDesiredBearing = getVar("$desiredBearing", -1);
    if (currentDesiredBearing != lastDesiredBearing && currentDesiredBearing != -1) {
        // If you want ARC to report desired bearing immediately:
        // send it as actual-bearing-style packet if your protocol uses that command
        lastDesiredBearing = currentDesiredBearing;
    // Layer 2: Packet building
    // This already happens inside sendStopMotors(), sendActualBearing(), sendWaypointData(), etc.
    // Example: send waypoint once when some project variable says to start
    if (getVar("$sendWaypointNow") == 1) {
        sendWaypointData(120000, 84000, 24000, 0, 97, 4, 79.35, 79.00, 0);
    // Layer 3: Packet parsing
    sleep(20);
ARDUINO UART SKETCH
ARDUINO UART Sketch
#include
// UART Protocol
static const uint8_t UART_HEADER = 0xA5;
// ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS         = 0x01;
static const uint8_t CMD_MISSED_IR           = 0x02;
static const uint8_t CMD_ACTUAL_BEARING      = 0x03;
static const uint8_t CMD_RIGHT_PIVOT         = 0x04;
static const uint8_t CMD_LEFT_PIVOT          = 0x05;
static const uint8_t CMD_WAYPOINT_DATA       = 0x06;
static const uint8_t CMD_OBS_SCAN_COMPLETE   = 0x07;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK             = 0x10;
static const uint8_t RSP_TOTAL_STEPS         = 0x11;
static const uint8_t RSP_DESIRED_BEARING     = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST    = 0x13;
// Run state
int RUN = 0;
// Parser state machine
enum ParserState {
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_PAYLOAD
ParserState state = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t payload[32];
uint8_t payloadIndex = 0;
uint8_t expectedLength = 0;
// Example navigation variables
uint32_t totalStepsTaken = 0;
uint16_t desiredBearing100 = 0;
uint16_t actualBearing100 = 0;
// Waypoint packet fields
uint32_t pathTotalDistance = 0;
uint32_t combinedStepsDesired = 0;
uint32_t oppositeDistance = 0;
uint8_t bearingAlignment = 0;
uint16_t reflectorBearing100 = 0;
uint8_t sensorPrime = 0;
uint16_t waypointDesiredBearing100 = 0;
uint16_t waypointActualBearing100 = 0;
uint8_t trackDir = 0;
// Helpers
uint16_t readUInt16LE(const uint8_t* data) {
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
  return (uint32_t)data[0] |
         ((uint32_t)data[1] << 8) |
         ((uint32_t)data[2] << 16) |
         ((uint32_t)data[3] << 24);
void sendHeaderAndCmd(uint8_t cmd) {
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
void sendUInt16Packet(uint8_t cmd, uint16_t value) {
  Serial3.write(cmd);
  Serial3.write((uint8_t)(value & 0xFF));
  Serial3.write((uint8_t)((value >> 8) & 0xFF));
void sendUInt32Packet(uint8_t cmd, uint32_t value) {
  Serial3.write(cmd);
  Serial3.write((uint8_t)((value >> 16) & 0xFF));
  Serial3.write((uint8_t)((value >> 24) & 0xFF));
// TX functions
void sendNavAck() {
  sendHeaderAndCmd(RSP_NAV_ACK);
void sendTotalSteps(uint32_t steps) {
  sendUInt32Packet(RSP_TOTAL_STEPS, steps);
void sendDesiredBearing(uint16_t bearing100) {
  sendUInt16Packet(RSP_DESIRED_BEARING, bearing100);
void sendObstacleScanRequest() {
  sendHeaderAndCmd(RSP_OBS_SCAN_REQUEST);
// RX packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len < 23) return;
  pathTotalDistance        = readUInt32LE(&data[0]);
  combinedStepsDesired     = readUInt32LE(&data[4]);
  oppositeDistance         = readUInt32LE(&data[8]);
  bearingAlignment         = data[12];
  reflectorBearing100      = readUInt16LE(&data[13]);
  sensorPrime              = data[15];
  waypointDesiredBearing100= readUInt16LE(&data[16]);
  waypointActualBearing100 = readUInt16LE(&data[18]);
  trackDir                 = data[20];
  RUN = 1;
  Serial.print("Waypoint received. PathTotalDistance=");
  Serial.println(pathTotalDistance);
  Serial.print("CombinedStepsDesired=");
  Serial.println(combinedStepsDesired);
  Serial.print("OppositeDistance=");
  Serial.println(oppositeDistance);
  Serial.print("BearingAlignment=");
  Serial.println(bearingAlignment);
  Serial.print("ReflectorBearing100=");
  Serial.println(reflectorBearing100);
  Serial.print("SensorPrime=");
  Serial.println(sensorPrime);
  Serial.print("DesiredBearing100=");
  Serial.println(waypointDesiredBearing100);
  Serial.print("ActualBearing100=");
  Serial.println(waypointActualBearing100);
  Serial.print("TrackDir=");
  Serial.println(trackDir);
  sendNavAck();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
    case CMD_STOP_MOTORS:
      Serial.println("CMD_STOP_MOTORS received");
      RUN = 0;
      // stopMotors();
      sendTotalSteps(totalStepsTaken);
      break;
    case CMD_MISSED_IR:
      Serial.println("CMD_MISSED_IR received");
      // missedIR = true;
      break;
    case CMD_ACTUAL_BEARING:
      if (len >= 2) {
        actualBearing100 = readUInt16LE(data);
        Serial.print("Actual bearing received x100 = ");
        Serial.println(actualBearing100);
      break;
    case CMD_RIGHT_PIVOT:
      if (len >= 2) {
        uint16_t steps = readUInt16LE(data);
        Serial.print("Right pivot steps = ");
        Serial.println(steps);
        // pivotRight(steps);
      break;
    case CMD_LEFT_PIVOT:
      if (len >= 2) {
        Serial.print("Left pivot steps = ");
        // pivotLeft(steps);
      break;
    case CMD_WAYPOINT_DATA:
      handleWaypointPacket(data, len);
      break;
    case CMD_OBS_SCAN_COMPLETE:
      Serial.println("Obstacle scan complete received");
      // resume normal tracking
      break;
    default:
      Serial.print("Unknown command: ");
      Serial.println(cmd, HEX);
      break;
uint8_t getExpectedLength(uint8_t cmd) {
  switch (cmd) {
    case CMD_STOP_MOTORS:       return 0;
    case CMD_MISSED_IR:         return 0;
    case CMD_ACTUAL_BEARING:    return 2;
    case CMD_RIGHT_PIVOT:       return 2;
    case CMD_LEFT_PIVOT:        return 2;
    case CMD_WAYPOINT_DATA:     return 23;
    case CMD_OBS_SCAN_COMPLETE: return 0;
    default:                    return 0xFF;
void processIncomingByte(uint8_t b) {
  switch (state) {
    case WAIT_HEADER:
      if (b == UART_HEADER) {
        state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      expectedLength = getExpectedLength(currentCmd);
      if (expectedLength == 0xFF) {
      } else if (expectedLength == 0) {
        handlePacket(currentCmd, nullptr, 0);
      } else {
        payloadIndex = 0;
        state = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLength) {
        handlePacket(currentCmd, payload, expectedLength);
      break;
void readIncomingUart() {
  while (Serial3.available() > 0) {
    uint8_t b = (uint8_t)Serial3.read();
    processIncomingByte(b);
// Setup / Loop
void setup() {
  Serial.begin(115200);
  Serial3.begin(115200);
  Serial.println("Combined Arduino UART sketch ready");
void loop() {
  // Always read incoming data
  readIncomingUart();
  if (RUN == 0) {
    // Idle / alignment / pre-navigation logic
    // Example: if a waypoint is received, RUN becomes 1 in handleWaypointPacket()
  else if (RUN == 1) {
    // Forward navigation logic
    // Update total steps
    totalStepsTaken = 123456; // replace with real step calculation
    // Example periodic reporting
    // sendTotalSteps(totalStepsTaken);
    // Example: if desired bearing changes
    // sendDesiredBearing(desiredBearing100);
  // Add a small delay if needed
  // delay(1);
I am requesting: 1.  Can you review/rewrite both the ARC UART and ARDUINO UART scripts to accomplish the printed objectives? 2.  Can you provide a standalone ARC script that will populate the global variables separately from the ARC UART script?
I'm not sure providing global variable values in the ARC UART script might overly complicate matters.  I intend to set the global variables separately and update them as necessary.  Let's keep the UART scripts primarily doing UART functions.  Remember for ARC UART, the WAYPOINT DATA is always sent and then only once.  The RIGHT PIVOT + STEPS or the LEFT PIVOT + STEPS may be sent, if required, and then only once after the WAYPOINT DATA.
Thank you for your continued efforts to help me.  Jack.
Yes - that’s a good step back, and I agree with your instinct:
  • Keep the UART scripts focused on UART
  • Keep the global values in a separate setup script
  • Avoid extra timing logic unless it’s truly needed
If the EZ-B is dropping offline, the first thing to do is reduce complexity, then add features back one at a time.
Recommended simplified architecture
1) UART_TX_RX script
This script should only:
  • send Waypoint Data once
  • optionally send Right Pivot + Steps once
  • optionally send Left Pivot + Steps once
  • send Stop / Missed IR / Actual Bearing only when triggered
  • read Arduino responses in the same loop
2) UART_INIT script
This separate script should only:
  • define and/or set the global variables used by the UART script
That is the cleaner design.
Important issue in your current ARC script
The line:
var currentActualBearing = getVar("$actualBearing",-1);
if(currentActualBearing != lastActualBearing && currentActualBearing != -1){
is fine conceptually, but if $actualBearing is being updated frequently elsewhere, it can still cause rapid UART traffic.
So to keep things simple, I recommend:
  • do not auto-send actual bearing continuously
  • send it only when an explicit trigger flag is set
That keeps the logic predictable and much safer.
1) Standalone ARC global initialization script
Use this in a separate Script skill named something like UART_INIT.
// UART_INIT - run once or whenever you want to reset values
setVar("$leftPivotSteps", 2500);
// 0 = DA, 1 = OA
// 0 = FD, 1 = RD
// Trigger flags
setVar("$sendRightPivotNow", 0);
setVar("$sendLeftPivotNow", 0);
setVar("$sendActualBearingNow", 0);
setVar("$sendStopNow", 0);
setVar("$sendMissedIRNow", 0);
setVar("$sendObsScanCompleteNow", 0);
2) Simplified ARC UART script
This version removes continuous bearing auto-send and uses explicit trigger variables instead.
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
    return [
        value & 0xFF,
function sendActualBearing() {
    var bearing = parseFloat(getVar("$actualBearing", -1));
    if (isNaN(bearing) || bearing < 0) {
        print("Skipping actual bearing: invalid value");
        return;
    var bearing100 = Math.round(bearing * 100);
    print("Sent ACTUAL BEARING: " + bearing);
function sendRightPivot() {
    var steps = parseInt(getVar("$rightPivotSteps", 0));
    if (isNaN(steps) || steps < 0) {
        print("Skipping right pivot: invalid steps");
        return;
    print("Sent RIGHT PIVOT: " + steps);
function sendLeftPivot() {
    var steps = parseInt(getVar("$leftPivotSteps", 0));
        print("Skipping left pivot: invalid steps");
        return;
    print("Sent LEFT PIVOT: " + steps);
function sendWaypointData() {
    var pathTotalDistance = parseInt(getVar("$pathTotalDistance", 0));
    var combinedStepsDesired = parseInt(getVar("$combinedStepsDesired", 0));
    var oppositeDistance = parseInt(getVar("$oppositeDistance", 0));
    var bearingAlignment = parseInt(getVar("$bearingAlignment", 0)) & 0xFF;
    var reflectorBearing = parseFloat(getVar("$reflectorBearing", 0));
    var sensorPrime = parseInt(getVar("$sensorPrime", 0)) & 0xFF;
    var desiredBearing = parseFloat(getVar("$desiredBearing", 0));
    var actualBearing = parseFloat(getVar("$actualBearing", 0));
    var trackDir = parseInt(getVar("$trackDir", 0)) & 0xFF;
    if (
        isNaN(pathTotalDistance) ||
        isNaN(combinedStepsDesired) ||
        isNaN(oppositeDistance) ||
        isNaN(reflectorBearing) ||
        isNaN(sensorPrime) ||
        isNaN(desiredBearing) ||
        isNaN(actualBearing)
        print("Skipping waypoint: invalid global variable(s)");
        return;
    var payload = [];
    print("Sent WAYPOINT DATA");
            continue;
            print("RX: NAV ACK");
            continue;
                sleep(1);
            var steps = (data[0]) | (data[1] << 8) | (data[2] << 16) | (data[3] << 24);
            print("RX: Total Steps Taken = " + steps);
            continue;
                sleep(1);
            print("RX: Desired Bearing = " + (bearing100 / 100.0));
            continue;
            print("RX: Obstacle Scan Request");
            setVar("$sendObsScanCompleteNow", 1);
            continue;
        print("RX: Unknown command = " + cmd);
while (true) {
    // TX triggers
    if (getVar("$sendStopNow", 0) == 1) {
        sendStopMotors();
    if (getVar("$sendMissedIRNow", 0) == 1) {
        sendMissedIR();
    if (getVar("$sendActualBearingNow", 0) == 1) {
        sendActualBearing();
    if (getVar("$sendRightPivotNow", 0) == 1) {
        sendRightPivot();
    if (getVar("$sendLeftPivotNow", 0) == 1) {
        sendLeftPivot();
    if (getVar("$sendWaypointNow", 0) == 1) {
        sendWaypointData();
    if (getVar("$sendObsScanCompleteNow", 0) == 1) {
        sendPacket(CMD_OBS_SCAN_COMPLETE, []);
        print("Sent OBS SCAN COMPLETE");
    // RX processing
    sleep(20);
3) Why this should be more stable
This version avoids:
  • automatic bearing spamming
  • repeated sending from a constantly changing variable
  • parseFloat() being used on every loop for a transmit decision
  • mixed responsibilities in the same code path
Instead, it only sends when you deliberately set a trigger flag to 1.
4) How to use it
Send waypoint once
Send right pivot once
setVar("$sendRightPivotNow", 1);
Send left pivot once
setVar("$sendLeftPivotNow", 1);
Send actual bearing once
setVar("$actualBearing", 79.35);
setVar("$sendActualBearingNow", 1);
5) Arduino sketch alignment
Your Arduino sketch should also remain simple:
  • read header
  • read command
  • read exact payload length
  • act on it
  • send responses when needed
Your packet lengths should be:
  • STOP = 0
  • MISSED IR = 0
  • ACTUAL BEARING = 2
  • RIGHT PIVOT = 2
  • LEFT PIVOT = 2
  • WAYPOINT DATA = 21 bytes
  • OBS SCAN COMPLETE = 0
6) One question before I refine the Arduino code again
For WAYPOINT DATA, do you want:
  1. desiredBearing and actualBearing included in the packet as you currently have, or
  2. do you want Arduino to compute/store those separately and remove them from the waypoint packet?
If you want, I can next give you:
  • a cleaned Arduino sketch v2
  • and a minimal test version of both scripts for one command at a time
That would make it much easier to isolate the exact point where the EZ-B goes offline.
#29
Hi @Athena, I am very enthusiastic about the direction you are taking now.  It appears you have completely understood my objectives.   For the WAYPOINT DATA, please send (desiredBearing and actualBearing) from the ARC UART script to the ARDUINO UART script.
ARDUINO Structure for variable (RUN): ARDUINO UART, while in the (RUN = 0 LOOP) receives the WAYPOINT DATA, and any RIGHT PIVOT or LEFT PIVOT commands.  When ARDUINO UART sends ACK (of WAYPOINT DATA) it changes RUN = 1.  When RUN = 1, then forward motion is started and all other UART TX and RX functions will become operational.
Can you provide a cleaned Arduino sketch v2 that is structured as described for variable (RUN)?  I intend to use the just provided Simplified ARC UART script to communicate with the Arduino sketch v2.
Thank you. Jack
Absolutely,Jack - here is a cleaned Arduino sketch v2 structured around your RUN variable exactly as you described.
It is designed to work with your Simplified ARC UART Script and assumes:
  • WAYPOINT DATA is received only in RUN = 0
  • RIGHT PIVOT and LEFT PIVOT can also be received in RUN = 0
  • once waypoint data is accepted, Arduino sends NAV ACK
  • after NAV ACK, Arduino sets RUN = 1
  • in RUN = 1, forward navigation logic runs and UART status handling remains active
Arduino UART Sketch v2
#include <Arduino.h>
// UART PROTOCOL
// ARC -> Arduino
// Arduino -> ARC
// RUN STATE
int RUN = 0;   // 0 = setup/alignment, 1 = forward navigation
// PARSER STATE
enum ParserState {
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_PAYLOAD
// NAV / WAYPOINT VARIABLES
// BYTE HELPERS
void writeUInt16LE(uint16_t value) {
void writeUInt32LE(uint32_t value) {
  Serial3.write(cmd);
  sendHeaderAndCmd(cmd);
  writeUInt16LE(value);
  writeUInt32LE(value);
// TX TO ARC
void sendNavAck() {
  Serial.println("TX:NAV ACK");
  Serial.print("TX:Total Steps = ");
  Serial.print("TX:Desired Bearing x100 = ");
  Serial.println(bearing100);
  Serial.println("TX:Obstacle Scan Request");
// MOTOR / NAVIGATION STUBS
// Replace these with your real stepper logic
void stopMotors() {
  Serial.println("Action: stopMotors()");
  // add stepper stop code here
void pivotRight(uint16_t steps) {
  Serial.print("Action: pivotRight(");
  Serial.print(steps);
  Serial.println(")");
  // add stepper pivot-right code here
void pivotLeft(uint16_t steps) {
  Serial.print("Action: pivotLeft(");
  // add stepper pivot-left code here
void beginForwardNavigation() {
  Serial.println("Action: beginForwardNavigation()");
  RUN = 1;
// WAYPOINT HANDLER
// Payload = 21 bytes:
// 0-3   pathTotalDistance      uint32
// 4-7   combinedStepsDesired   uint32
// 8-11  oppositeDistance       uint32
// 12    bearingAlignment       uint8
// 13-14 reflectorBearing100    uint16
// 15    sensorPrime            uint8
// 16-17 desiredBearing100      uint16
// 18-19 actualBearing100       uint16
// 20    trackDir               uint8
  if (len != 21) {
    Serial.print("Waypoint length mismatch: ");
    Serial.println(len);
    return;
  waypointDesiredBearing100 = readUInt16LE(&data[16]);
  Serial.println("RX: WAYPOINT DATA received");
  Serial.print("pathTotalDistance = ");        Serial.println(pathTotalDistance);
  Serial.print("combinedStepsDesired = ");     Serial.println(combinedStepsDesired);
  Serial.print("oppositeDistance = ");         Serial.println(oppositeDistance);
  Serial.print("bearingAlignment = ");         Serial.println(bearingAlignment);
  Serial.print("reflectorBearing100 = ");      Serial.println(reflectorBearing100);
  Serial.print("sensorPrime = ");              Serial.println(sensorPrime);
  Serial.print("desiredBearing100 = ");        Serial.println(waypointDesiredBearing100);
  Serial.print("actualBearing100 = ");         Serial.println(waypointActualBearing100);
  Serial.print("trackDir = ");                 Serial.println(trackDir);
  // Store received bearing values for RUN=1 use
  desiredBearing100 = waypointDesiredBearing100;
  actualBearing100   = waypointActualBearing100;
  // Confirm waypoint reception before switching to RUN=1
  sendNavAck();
  // Start forward motion after ACK
  beginForwardNavigation();
// PACKET DISPATCH
  switch (cmd) {
      Serial.println("RX: STOP MOTORS");
      stopMotors();
      RUN = 0;
      break;
    case CMD_MISSED_IR:
      Serial.println("RX: MISSED IR");
      // put recovery logic here
      break;
      if (len == 2) {
        Serial.print("RX: Actual Bearing x100 = ");
      break;
      if (len == 2) {
        Serial.print("RX: Right Pivot steps = ");
        pivotRight(steps);
      break;
      if (len == 2) {
        Serial.print("RX: Left Pivot steps = ");
        pivotLeft(steps);
      break;
      if (RUN == 0) {
      } else {
        Serial.println("RX: WAYPOINT ignored because RUN != 0");
      break;
      Serial.println("RX: Obstacle Scan Complete");
      // resume normal forward tracking behavior here
      break;
    default:
      Serial.print("RX: Unknown command 0x");
      break;
  switch (cmd) {
    case CMD_WAYPOINT_DATA:     return 21;
  switch (state) {
    case WAIT_HEADER:
        state = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      } else {
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
// SETUP / LOOP
void setup() {
  Serial.println("Arduino UART sketch v2 ready");
void loop() {
  // Always listen for incoming UART bytes
  readIncomingUart();
  if (RUN == 0) {
    // Alignment / pivot / waypoint setup phase
    // Keep this light. Waypoint handling occurs in UART RX.
    // Forward navigation phase
    // Put your step counting, PWM correction, and bearing logic here
    // Example placeholder:
    // totalStepsTaken = ...
    // Example periodic status reporting if needed:
  // Small yield if your loop gets too busy
  // delay(1);
Notes on this version
What this sketch does
  • parses binary UART packets
  • accepts WAYPOINT DATA only in RUN = 0
  • accepts RIGHT PIVOT and LEFT PIVOT in RUN = 0
  • sends NAV ACK after waypoint is stored
  • switches to RUN = 1
  • leaves RUN = 1 available for your forward motion logic
  • keeps UART parsing always active
What you still need to add
You’ll still replace these stubs with your real code:
  • stopMotors()
  • pivotRight()
  • pivotLeft()
  • forward motion / PWM correction logic in RUN = 1
Important compatibility note
Your ARC script must send exactly 21 bytes of payload for CMD_WAYPOINT_DATA.
If you want, I can next do one of these:
  1. rewrite your Simplified ARC UART script one final time so it matches this Arduino v2 sketch exactly, or
  2. add your actual stepper motor logic placeholders into this Arduino sketch so it looks closer to your real project.
If you’d like, I can also give you a minimal test pair next: one waypoint packet only, so you can verify the link before adding pivots and bearing updates.
#31
Hi @Athena, Please rewrite the Simplified ARC UART script one final time so it matches this Arduino v2 sketch exactly. Thank you. Jack
Absolutely,Jack. Below is a final simplified ARC UART JavaScript script that matches the Arduino v2 sketch exactly:
  • Header: 0xA5
  • ARC Arduino commands:
    • 0x01 Stop Motors
    • 0x02 Missed IR
    • 0x03 Actual Bearing
    • 0x04 Right Pivot
    • 0x05 Left Pivot
    • 0x06 Waypoint Data
    • 0x07 Obstacle Scan Complete
  • Arduino ARC responses:
    • 0x10 NAV ACK
    • 0x11 Total Steps Taken
    • 0x12 Desired Bearing Update
    • 0x13 Obstacle Scan Request
This version is intentionally kept simple and trigger-based, so ARC only sends packets when you set a variable to 1.
ARC UART Script v2
var UART_INDEX = 0;
// ARC -> Arduino
// Arduino -> ARC
// Helpers
function safeInt(v, def) {
    var n = parseInt(v);
    if (isNaN(n)) return def;
    return n;
function safeFloat(v, def) {
    var n = parseFloat(v);
    return n;
    return [
        value & 0xFF,
        (value >> 8) & 0xFF
    return [
        value & 0xFF,
// TX functions
    print("TX: STOP");
    print("TX: MISSED IR");
    var bearing = safeFloat(getVar("$actualBearing", -1), -1);
    if (bearing < 0) return;
    print("TX: ACTUAL BEARING = " + bearing);
    var steps = safeInt(getVar("$rightPivotSteps", 0), 0);
    print("TX: RIGHT PIVOT = " + steps);
    var steps = safeInt(getVar("$leftPivotSteps", 0), 0);
    print("TX: LEFT PIVOT = " + steps);
    var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0);
    var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0);
    var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0);
    var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0) & 0xFF;
    var reflectorBearing = safeFloat(getVar("$reflectorBearing", 0), 0);
    var sensorPrime = safeInt(getVar("$sensorPrime", 0), 0) & 0xFF;
    var desiredBearing = safeFloat(getVar("$desiredBearing", 0), 0);
    var actualBearing = safeFloat(getVar("$actualBearing", 0), 0);
    var trackDir = safeInt(getVar("$trackDir", 0), 0) & 0xFF;
    var payload = [];
    print("TX: WAYPOINT DATA sent");
// RX processing
            continue;
            setVar("$run", 1);
            continue;
                sleep(1);
            print("RX: TOTAL STEPS = " + steps);
            continue;
                sleep(1);
            var d = UART.hardwareUartRead(UART_INDEX, 2);
            var bearing100 = d[0] | (d[1] << 8);
            print("RX: DESIRED BEARING = " + (bearing100 / 100.0));
            continue;
            print("RX: OBSTACLE SCAN REQUEST");
            setVar("$obsScan", 1);
            continue;
// Main loop
while (true) {
    // Trigger-based TX only
        sendStopMotors();
        sendMissedIR();
        sendRightPivot();
        sendLeftPivot();
        sendWaypointData();
        print("TX: OBS SCAN COMPLETE");
    // Always read incoming UART
    sleep(20);
How to use it
Set the trigger variables from another ARC script or control:
Send waypoint once
Send stop
setVar("$sendStopNow", 1);
One important note
This script assumes:
  • $actualBearing is already being set elsewhere
  • $desiredBearing, $reflectorBearing, $pathTotalDistance, etc. are already set elsewhere
  • the Arduino is using the exact same packet format
  • Serial3 on the Arduino is wired correctly to the EZ-B UART
If you want, I can now give you a clean matching global-variable initialization script for ARC, or I can help you make a first test packet so you can verify just WAYPOINT DATA before enabling the other triggers.
