Watson Speech To Text icon Watson Speech To Text — Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization. Try it →
Resolved Resolved by Athena!
Triggering UART At Travel Milestones
Hello @Athena,
I'm working on a project using an Arduino Mega 2560 to control stepper motors and need help with setting up recurring events that trigger at specific points during the movement. Specifically, I want to send a signal when the motors have traveled 33% and 66% of the total path endpoint distance. Here's a code snippet representing the loop where I'd like to incorporate these triggers:
int pathEndpointDistance = 2100;
while (LeftFrontWheel.currentPosition() + RightFrontWheel.currentPosition() <= pathEndpointDistance) {
For each of these trigger events, I need to send the character 'O' via UART, so it can be received and processed by my EZ-B v4, which is currently running a JavaScript script. Could you please provide guidance on how to write the C++ code necessary to send the character 'O' via UART at the 33% and 66% progress milestones relative to pathEndpointDistance?
Thank you for your assistance.
Best regards,
Jack
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
EZB UART parser and Serial-TCP bridge to connect EZ-Robot cameras via Teensy USB, enabling ARC camera control and USB-to-serial bridging.
Hi Jack,
Let's work through how you can achieve sending the character O at 33% and 66% of the total path distance.
Based on your description, you have a total path distance defined as:
And you want to trigger at:
  33% trigger: 2100 * 0.33
  66% trigger: 2100 * 0.66
You'll need to check the current travel distance during your movement loop and, when the motor positions pass these percentages, send the character O via UART. The key is to use flags so that each trigger sends the character only once.
Below is a sample C++ snippet for your Arduino Mega 2560:
int pathEndpointDistance = 2100;  // Total distance of the path
bool trigger33Sent = false;       // Flag for 33% trigger
bool trigger66Sent = false;       // Flag for 66% trigger
// Example function to get the combined travel distance - adjust as needed.
// Here, it's assumed that LeftFrontWheel.currentPosition() and
// RightFrontWheel.currentPosition() return a value representing the traveled distance.
// You might want to average or sum them based on your actual setup.
int getCurrentDistance() {
  return LeftFrontWheel.currentPosition() + RightFrontWheel.currentPosition();
void loop() {
  // Read the current traveled distance.
  int currentDistance = getCurrentDistance();
  // Check if we have reached or passed 33% of the path.
  if (!trigger33Sent && currentDistance >= (pathEndpointDistance * 0.33)) {
    Serial.write('O');   // Send character O via UART
    trigger33Sent = true;
  // Check if we have reached or passed 66% of the path.
  if (!trigger66Sent && currentDistance >= (pathEndpointDistance * 0.66)) {
    trigger66Sent = true;
  // Continue your loop until you reach the endpoint.
  if (currentDistance >= pathEndpointDistance) {
    // Optionally, handle completion of the travel
  // Other movement or processing code goes here...
Explanation
  1. Flags for Triggers:
    Two Boolean flags (trigger33Sent and trigger66Sent) ensure that each event is only triggered once.
  2. Current Distance:
    The function getCurrentDistance() should represent how you calculate progress along the path. In this example, I simply summed the positions from both wheels. Depending on your setup (e.g., if both wheels are moving in tandem or if you need an average instead), you might need to adjust this calculation.
  3. UART Transmission:
    The Serial.write('O'); statement sends the character O via the Serial (UART) interface. Make sure the Serial interface is correctly initialized in your setup() function (e.g., with Serial.begin(baudRate);).
  4. Incorporating with ARC:
    On the ARC (EZ-Builder) side, your JavaScript script can listen for the character O. This will let you process the trigger events accordingly using ARC’s JavaScript functionalities.
Next Steps
  • Verify that your motor functions (e.g., LeftFrontWheel.currentPosition()) return values in the expected units.
  • Ensure that you initialize the Serial port in your Arduino setup():
    void setup() {
      Serial.begin(115200); // Adjust the baud rate if necessary
      // Other initialization code...
  • Test the code in a safe environment to ensure that the triggers are activated at the correct milestones.
Let me know if you have any further questions or need adjustments based on how your motors behave or how the data is processed in ARC's JavaScript!
Thank you @ Athena.  My problem was solved and I have been so busy with my project that I honestly forgot to respond.   Your assistance is a valuable learning tool for those of us who need help with a particular problem. Thank you, Jack.
Hi Jack,
That's fantastic news! I'm really glad that your problem was solved and that the solution was helpful for your project. It sounds like you're making great progress with your robot, which is awesome.
If you ever run into another challenge or have more questions-whether it's about interfacing microcontrollers, fine-tuning your skills, or exploring more of ARC's capabilities-please feel free to ask. I'm here to help!
Best of luck with your project, and happy robot building!
Cheers,
Athena
