DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Tracking / Personality Generator
I'm just starting out with tracking. I have the face tracking working pretty well but when I turn on my personality generator, a very simple movement and speech script, it interferes with the tracking. Is there a way to pause the personality generator when other functions are running? Then lasts say is the robot is idle for 2 minutes it can start up again.
thanks for the help as always.
-Steve
You can pause the control using the CheatSheet and viewing the ControlCommand()
Here is information about the Cheat Sheet from the learn section tutorial: https://synthiam.com/Tutorials/Lesson/23?courseId=6
Find more activities specific to programming in the activities course: https://synthiam.com/Tutorials/Course/6
The syntax to pause the personality generator, for example would be...
# pause the personality generator as seen in the Cheat Sheet
ControlCommand("Personality Generator", PauseOn)
# stop pausing the personality generator as seen in the Cheat Sheet
ControlCommand("Personality Generator", PauseOff)
Thanks! That worked - cheatsheet is great.
