HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Touch Path Overshoot On Sphero Turns
I’m playing with a Sphero (Bluetooth to a Windows laptop) in ARC and trying to have it follow simple shapes using the Touch Path skill. The Sphero Movement Panel connects fine and I can drive it around smoothly. I used the Movement Panel’s aim/calibration so that pressing Forward makes Sphero roll straight away from me. Battery is topped up and the robot is about 1 meter from the PC.
In Touch Path, I set Movement Speed to 30 and Turning Speed to 70. When I draw a square, the first straight segment is okay, but each 90 turn is a wide ARC and it overshoots, then the following straights drift to the right. I tried lower movement (20) and higher turning (90), and also flipped it (movement 50, turning 60). I also tried on a hard floor and on a yoga mat in case traction was the issue. manual driving via the Movement Panel can make crisp direction changes if I briefly stop and then re-aim with small heading adjustments, but Touch Path’s automatic sequence doesn’t seem to pause enough between segments.
A couple of questions about how these two skills interact: does Touch Path send generic Left/Right commands that the Sphero Movement Panel translates into a rolling arc, or does it support an in-place heading change for Sphero (speed 0, new heading, then roll)? If it’s purely time-based forward/turns, is the recommended approach to insert a Movement Script between Touch Path and Sphero so Left/Right become "stop, set heading delta, short delay, then forward" for tighter corners? If so, is there a sample of intercepting Touch Path turn commands and converting them into Sphero-friendly heading changes without continuous rolling?
What’s the best-practice configuration (or scripting pattern) to get crisp 90 corners with Touch Path on a Sphero without the wide arcs and drift?
Sphero by Sphero
Control the Bluetooth Sphero with Synthiam ARC to add speech recognition, scripting and PandoraBot AI via the Sphero Movement Panel.
Bluetooth
Servos
UART
ADC
Digital
