Hello i think my camera was glued together as i cant get it apart at all i was hoping to connect it to my EZ-B like DJ did in this Video but nomatter what i do i cant open it at all
HELP
Camera Snapshot
— Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand.
HELP
Try harder. Some are very tough to get in to. My first one fell apart in transit which was great but my second was very tight. I had to run a blade around where the plastic and metal meet so I could fit a screw driver in there to lever it apart.
Brute force and ignorance may be required.
i just broke a brass screw driver trying to open it lol
ok i got it open it was exstreamly hard and i compleatly destroyed the case but now its open and i see that yes it was glued together there is a big gob of glue at the usb connection and its compleatly rapped in masking tape holding the batt in place now i hope a can find where to solder the trigger wire to and hope it still works lol
The camera is glued because it is meant to be in one piece. You would need to pry it apart (as detailed in my instructions) to separate it.
lol I pryed and pryed and pryed till she gave in and told me what was wong lol
i think i need a bigger workbench my table is just to small "as you can see" and the floor is hard on my back lol
now i just need to studie that video closely to try to see just where to solder that wight wire
Just there
Rich in your photo its hard to see just what that yellow wire is solderd to is it on the surfus mount device rite on the edge of the bourd or is it on the switches mounting post ???
Its not my photo, but I'm pretty sure its on the mounting post.
