Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Tablet Face
Many robots are built with installed tablets. Often the tablet is in a head. I was wondering if anyone has seen or could build a face that could be displayed on the screen. I have seen this idea around.
It consists of the basic face features eye brows, eyes and a mouth only. These features are able to move to show expression. Has anyone seen this feature or messed with one? Is it possible to build?
Ron R
Edit: The idea is like ROMO. I want only the face which could be run by an EZB.
DJ possible?
#66
Yes this is what I want ,,, and a how to do also.. Thanks Patrick !
goodluck.thumbs up.
Has anyone figures out Andy's original question pertaining to animated faces on flat panels?
I also would like to be able to call up animations smile, sad whatever animations. Are these animations called by scripts, maybe even reactive to voice synthesis etc. or eyes that follow you using the camera?
EzAng
#70   — Edited
ok, Thanks I tried that, it works, I will play around with it.
So to change face emotions, save different gifs or videos
I have the Wio terminal: I got as far as the WIO terminal - no audio / speech , nor mouth moves etc. check my kink out https://youtu.be/GzJ97RnYYnM
https://www.hackster.io/SeeedStudio/display-robot-face-using-the-wio-terminal-68f87a
works great, but has no audio
This is the code I used for the Wio Terminal, how can it be used for a script in Synthiam?
#include <LovyanGFX.hpp> #include <Servo.h>
Servo myservo;
//int outpin=D2;
int counter = 0; int i = 0; static LGFX lcd; static LGFX_Sprite sprite(&lcd);
int pos = 0;
void drawEye(int x, int y) { sprite.clear(); sprite.fillCircle(65,65,60,0xFFFF); //sprite.drawEllipse(65,65,60,30,0xFFFF); //sprite.drawFastHLine(5,62,120,0xFF); sprite.fillCircle(x,y,15,0); sprite.fillArc(65,65,60,1,180,360,0xED6E); sprite.setPivot(65,65); sprite.pushRotateZoom(80,70,0,1,0.5); sprite.pushRotateZoom(240,70,0,1,0.5); }
void sleepyEyes() { int p_rect[4][4] = {{9,65,112,22},{22,65,86,41},{40,65,49,55},{63,65,4,59}}; sprite.clear(); sprite.fillCircle(65,65,60,0xFFFF); sprite.fillCircle(65,70,10,0); //sprite.fillArc(65,65,60,1,180,360,0xED6E); sprite.setPivot(65,65); for (int i=0;i<4;i++) { sprite.fillArc(65,65,60,1,180,360,0xED6E); sprite.fillArc(65,65,60,1,0,22*(i+1),0xED6E); sprite.fillArc(65,65,60,1,180-(22*(i+1)),180,0xED6E); sprite.fillRect(p_rect[i][0],p_rect[i][1],p_rect[i][2],p_rect[i][3],0xED6E); sprite.pushRotateZoom(80,70,0,1,0.5); sprite.pushRotateZoom(240,70,0,1,0.5); delay(200); } delay(2000); //sprite.pushRotateZoom(80,70,0,1,0.5); //sprite.pushRotateZoom(240,70,0,1,0.5); }
void setup() { pinMode(WIO_5S_UP, INPUT_PULLUP); pinMode(WIO_5S_DOWN, INPUT_PULLUP);
myservo.attach(0);
lcd.init(); lcd.setRotation(3); lcd.setBrightness(128); lcd.setColorDepth(16); lcd.clear();
sprite.setColorDepth(16); sprite.createSprite(130, 130); drawEye(50,80); lcd.drawArc(160,90,120,119,30,150,0xE800);
void loop() { int x = random(15, 115);
for (pos = 0; pos <= 60; pos += 1) {
  int l = pos + 20;
  drawEye(l,80);
  myservo.write(pos);
  delay(80);
for (pos = 60; pos >= 0; pos -= 1) {
  int l = pos;
  drawEye(l,80);
  myservo.write(pos);
  delay(80);
delay(3000);
sleepyEyes();
