Can anyone answer if the EZB 4 will be capable of running a stepper motor? Will it require a separate motor controller? Thanks in advance.
Chris
Ubtech Alpha 1 Bluetooth
— Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs.
Chris
Yes and yes...
Have a read of this topic
The linked thread mentions using 12 - 24 volts to drive the motor even though it will probably have a much lower voltage specified. This is correct and is done in order to overcome the winding inductance and get a fast response time from the motor. However, this high voltage drive must be pulse width modulated to prevent the max. motor winding current from being exceeded. This is accomplished by monitoring the voltage across a low ohm resistor placed in series with the winding and turning the drive on or off as required.
