Camera NMS Pose icon Camera NMS Pose — Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control Try it →
Ssc-32 Speed Control
I'm currently installing and testing my new SSC-32 and testing servos using Servo(V0,xx) script commands which work great, and I'm trying to get a "connection" init script sorted to set virtual servo speeds on start up, but can't figure out how to control speed. A take it that the "ServoSpeed()" commands are not supported for virtual servos as it doesn't seem to be working for me?
One other thing, it's not a problem for me, but may be for others... in the SSC control config menu, when UART #0 is unchecked, I cannot select any other UART ports from the dropdown menu as no others are showing.
I left a post on the RobotShop forum about releasing servos using the SSC-32, and here's part of their response...
Quote:
There is no command currently to release a servo from holding a position (basically, to stop sending the pulse output). We will look into this for a possible update to the SSC-32U firmware.
We will investigate this possibility with the current firmware. It is possible there is a debug feature or an undocumented command that could be activated to permit this option.
If we come up with any new information on this situation we will post here again.
Sincerely,
so hopefully the will add this at some point.
