Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
Smtp Client Question
Question:
I have searched the EZ-Script manual for SMTP Client, No success. I have searched the page from which the client is download from: No success. If there is help about this I do apologize in advance.
The code works. I can email myself, what I would like to do is email other people. What is the syntax?
Thanks WayneA.
I'll modify the plugin for the new line. My bad
@ptp Yes sir, I tried to use but it seemed way over my head.
Never fear I will keep trying to use.
Upgrade to the latest plugin and use this:
ControlCommand("SMTP Client", Send, "JohnDoe AT somewhere.com", "John Doe", "mail subject", "This is a line\r\nThis is a new line")
@DJ Thank You very much. Hope I did not cause to much trouble.
Another question regarding format.
Is the new code added to the plugin able to handle string formatting. For example:
ControlCommand("SMTP Client", Send, "JohnDoe AT somewhere.com", "John Doe", "mail subject", "$sting1\r\n$string2")
With quotation marks, the email body simply displays the $string1\r\n$string2
If I do not use the quotation marks, nothing happens.
Is the plug in not supposed to handle string variables.
Thanks! WayneA
@WayneA:
string concatenation operation is not the same as handling special chars inside a string.
Try this:
ControlCommand("SMTP Client", Send, "JohnDoe AT somewhere.com", "John Doe", "mail subject", $string1 + "\r\n" + $string2)
#16
@ptp
That did not work. Thanks for you help.
