Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Resolved Resolved by Athena!
Skill Ultrasonic Distance - Unable to access it through ControlCommand
Skill Ultrasonic Distance - Unable To Access It Through Controlcommand
I expected to be able to access the Ultrasonic Distance skill using the ControlCommand, but it doesn't seem possible. Is this normal behavior?
Here are the steps I took:
  1. Added the Ultrasonic Distance skill.
  2. Added the Script skill.
  3. In the Script skill's Cheat Sheet tab, I don't see any instance for Ultrasonic Distance.
The same issue occurs if I right-click in the script editing area. Additionally, in the Global Variables tab, the $PingDistance variable does not appear. I've tried referencing it directly, but I'm obviously getting an error.
Here is my screenshot:
Ultrasonic Radar by Synthiam
Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing
Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
It seems like you're trying to access the Ultrasonic Distance skill using the ControlCommand() function in ARC, but you're encountering issues. Let's address your concerns step-by-step.
1. Accessing Ultrasonic Distance Skill via ControlCommand
The ControlCommand() function allows you to send commands to other robot skills within your ARC project. However, not all skills expose commands that can be accessed via ControlCommand(). The Ultrasonic Distance skills you mentioned (Ultrasonic Radar, Ultrasonic Collision Detection, and Ultrasonic Collision Script) may not have specific ControlCommand() functions available.
2. Using Global Variables
For the Ultrasonic Distance skills, the distance values are typically updated in real-time and can be accessed via global variables. However, if the $PingDistance variable is not appearing, it might be due to the specific configuration or the way the skill updates the variable.
Steps to Troubleshoot and Access Distance Values
A. Verify Skill Configuration
  1. Check Skill Settings: Ensure that the Ultrasonic Distance skills are correctly configured with the appropriate ports and intervals.
  2. Pause Checkbox: Make sure the "Pause" checkbox is unchecked in the skill settings to allow real-time updates.
B. Accessing Distance Values in Scripts
  1. Using GetPing() Function: You can use the GetPing() function to manually retrieve the distance value from the ultrasonic sensor. This function can be called within your script to get the latest distance reading.
    var distance = Ping.get(d0, d1); // Replace d0 and d1 with your actual trigger and echo ports
    print("Distance: " + distance);
  2. Using Global Variables: If the skill updates a global variable, you can access it using the getVar() function.
    var distance = getVar("$PingDistance");
C. Example Script for Ultrasonic Collision Script
Here is an example script that uses the Ping.get() function to retrieve the distance and perform actions based on the distance value:
// Stop the robot from moving
Movement.stop();
// Speak and let us know what's going on
Audio.say("I see an object");
// Reverse for 2 seconds
Movement.reverse();
sleep(2000);
Movement.stop();
// Set a slow speed for turning
Movement.setSpeed(50);
// Begin turning to the right
Movement.right();
while (true) {
    // Get the latest value from the ultrasonic sensor
    // Check if the path is clear
    if (distance > 20) {
        // Stop turning
        Movement.stop();
        // Let us know the path is clear by speaking
        Audio.say("Path is clear");
        // Exit the script
        halt();
    // Pause while we are turning
    sleep(200);
Additional Resources
If you continue to experience issues, please provide more details or screenshots of your configuration, and I'll be happy to assist further.
Thanks @Athena!
You're welcome, Taubore! If you have any more questions or need further assistance with your EZ-B v4 or ARC project, feel free to ask. Happy robot building!
