Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Servo Mounted Security Camera (2-Axis)
I am well on the way in the programming of my security camera. Camera servo tracking is enabled for the two servos- the horizontal and vertical axis. When one of the two servos moves to follow movement the alarm will be activated, starting both the Alert and Snapshot scripts. Here are the scripts I have written for the camera:
System On Script
ControlCommand("Security Script 1", ScriptStart)
ControlCommand("Security Script 2", ScriptStart)
ControlCommand("Camera", PauseOff)
Security Script 1*
Servo(D1, 35)
Sleep(1)
Say(Security System Active)
WaitForServoMove(D1)
ControlCommand("Security Script 2", ScriptStop)
ControlCommand("Movement Detected Script", ScriptStart)
*Horizontal axis
Security Script 2*
Servo(D2 ,35)
Sleep(1)
WaitForServoMove(D2)
ControlCommand("Security Script 1", ScriptStop)
*Vertical axis
ControlCommand("Alert Script", ScriptStart)
ControlCommand("Snapshot Script", ScriptStart)
Alert Script
ControlCommand("Alert Script", ScriptStop)
ControlCommand("Snapshot Script", ScriptStop)
ControlCommand("Camera Snapshot", PauseOn)
Say(Security System Off)
Snapshot Script
ControlCommand("Camera Snapshot", PauseOff)
Sleep(2001)
Stop Script
Continuous Scan Script
ServoSpeed(D1, 35)
: Start
Sleep(100)
Servo(D1, 1)
Sleep(3000)
Servo(D1, 70)
Sleep(3000)
Goto(Start)
Scan Left Script
ServoSpeed(D1, 35)
Servo(D1, 1)
Scan Right Script
ServoSpeed(D1, 35)
Servo(D1, 70)
Scan Stop Script
ControlCommand("Scan Script", ScriptStop)
Servo(D1, 35)
ServoSpeed(D1, 25)
NB: I am unsure what speed the values in the ServoSpeed command represent. The current values are merely estimates
There are all the scripts neccessary for the camera functionality. There are others but they are simply for the joystick and other components.
After a while I decided that I would use a joystick to start and stop certain scripts, toggle the pause on the camera and camera snapshots and also to rotate the two servos. But because of the commands I have used in the Security Script when I overide the camera servo tracking it activates the alarm. I could just stop the script every time I wanted to rotate it but I will wait until DJ includes the Motion Found and Lost functions of the Camera.
Woops. I don't know how I put this thread in the wrong catergory. I will copy it right away
It's not a robot project. It's related to script/ARC, belongs in here:)
Project showcase is for a video/pics of a working robot (i.e. project)
Ahhhh. Sadly I already copied it to Project Showcase. Can you use your spectacular admin powers to delete it?
I wish i had admin powers. I have hax0r powers. There is no admin interface for this:) We go right into the database and delete haha
It's already gone. That was fast. You do have powers then and not just ones that affect the computing world. Can you predict the numbers for the next lottery?
hahha i wish!
Perhaps you can build a robot that can. Hack one of this old fair-ground fortune tellers and you will know everything
Does anyone have any suggestions on how I will be able to extend the programming of my camera or add to it?
