pashley
I am coming from the Parallax Boe-Bot world, where one uses programming to change the direction (clockwise vs counterclockwise) of the servo motors to rotate the wheels of your robot. Left goes one way, right goes the other.
I am experimenting with the EZ-B using my Boe Bot chasis, but cannot figure out how to get both wheels spinning in the same direction using EZ-builder. It is probably something real obvious, but I need help, please.
Get access to the latest features and updates with ARC Early Access edition. You'll have everything that's needed to unleash your robot's potential!
i think if you hit up(forward) they both move in the same direction. same goes for down (reverse)
if you hit left or right, thats when the tracks or wheels move in opposite directions.
I changed the forward and reverse values in increments of 10 for both left and right wheel servos, but alas, the right still rotates clockwise and the left counterclockwise. Nice rotational spin, though. I'll keep at it - thanks again.
