Hello! I don't seem to be able to find the dimensions of the servos (length, width, height, shaft diameter). Does anyone have that information? Thanks!
AB2012
— Edited
Sound Servo (PC Speaker)
— Maps PC audio volume to servos in real time with scalar, min/max, invert & multi-servo options-ideal for syncing robot mouth to sound
Any specific make or model? Or are you specifically asking about the ones in the EZ-B complete kit?
I've found that every website where I've looked to buy servos from will give the technical data sheets which have the dimensions on them.
Generally a standard servo is roughly 55.5 x 20 x 42mm but I assume different manufacturers will have slightly different dimensions...
Sorry, I should have been more specific. Yes, I am asking about the ones in the EZ-B kit.
Servos:
EZ-B:
Thank you!
