Is there any way to send a UDP command from within ARC?
I have some Limitlessled wifi lights I would love to control.
Anyone got any insights? Examples of how thhey did it.... etc?
Com Port Manager
— Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART.
Have you tried with the HTTPGet command?
I just checked their website and they say you can control them over the internet via the ip on port 50000 so it's likely to be just a case of figuring out the correct url for each function.
I added a SendUDP() to the next ARC for you... I'll release it tonight or tomorrow - depends on my weekend
Here's info from their website for LimitlessLED Smart Lights...
All UDP Commands are 3 Bytes. First byte is from the list below, plus a fixed 2 byte suffix of 0x00 (decimal: 0) and 0x55 (decimal: 85)
i.e. to turn all RGBW COLOR LimitlessLED Smart lights to ON then send the TCP/IP UDP packet of: 0x42 0x00 0x55
RGBW COLOR LED ALL OFF 0x41 65
RGBW COLOR LED ALL ON 0x42 66
DISCO SPEED SLOWER 0x43 67
DISCO SPEED FASTER 0x44 68
GROUP 1 ALL ON 0x45 69 (SYNC/PAIR RGB+W Bulb within 2 seconds of Wall Switch Power being turned ON)
GROUP 1 ALL OFF 0x46 70
GROUP 2 ALL ON 0x47 71 (SYNC/PAIR RGB+W Bulb within 2 seconds of Wall Switch Power being turned ON)
GROUP 2 ALL OFF 0x48 72
GROUP 3 ALL ON 0x49 73 (SYNC/PAIR RGB+W Bulb within 2 seconds of Wall Switch Power being turned ON)
GROUP 3 ALL OFF 0x4A 74
GROUP 4 ALL ON 0x4B 75 (SYNC/PAIR RGB+W Bulb within 2 seconds of Wall Switch Power being turned ON)
GROUP 4 ALL OFF 0x4C 76
DISCO MODE 0x4D 77
SET COLOR TO WHITE (GROUP ALL) 0x42 100ms followed by: 0xC2
SET COLOR TO WHITE (GROUP 1) 0x45 100ms followed by: 0xC5
SET COLOR TO WHITE (GROUP 2) 0x47 100ms followed by: 0xC7
SET COLOR TO WHITE (GROUP 3) 0x49 100ms followed by: 0xC9
SET COLOR TO WHITE (GROUP 4) 0x4B 100ms followed by: 0xCB
https://www.limitlessled.com/ ...worth visiting and a big thank you to DJ for adding UDP! I had no idea what that was ..until now! Looks like More home control (Jarvis) features now besides robot control....
DJ Sures you are awesome...
I feel like a child following the Pied Piper... you amaze me!
I almost had to choked back a tear when I explained to my students the level of service and support you give to us and the innovative, ground breaking stuff I get to be part of by simple association.
Seriously - you rock my world and if you ever get to NZ....
Wow, thank you for the kind words
It's feedback like that - which makes it worth it! Thanks again
