Resolved Resolved by Athena AI!
Sending Float Value Via UART
Hello @Athena,
I would like some assistance with sending a floating-point value via UART from an EZ-B v4 using JavaScript to an Arduino Mega using C++. Here's a snippet of my current code:
EZ-B v4 JavaScript Code:
UART.initHardwareUart(0, 9600);
var actualCourse = 91.55;
// Need an appropriate method to send the floating-point value correctly
UART.hardwareUartWrite(0, [actualCourse]);
Arduino Mega C++ Code:
float actualCourse;
void setup() {
  resetAll();
  Serial3.begin(9600);  // Communication with EZ-B
  Serial.begin(9600);   // Debugging via Serial Monitor
void loop() {
  if (Serial3.available() >= 1) {
    byte incomingByte = Serial3.read();
    delay(100);
    if (incomingByte == 'A') {  // Confirm header byte
      Serial.print("incomingByte:  ");
      Serial.println('A');
      actualCourse = Serial3.read();  // This approach doesn't handle float correctly
      Serial.print("actualCourse: ");
      Serial.println(actualCourse);
My objective is to transmit the entire floating-point value of "actualCourse" (91.55) via UART without any loss of precision or rounding issues. Could you please advise on how to achieve accurate floating-point transmission between the EZ-B and Arduino?
Thank you,
Jack
Related Hardware Roli Rover
Related Control Serial Toolbox
Below is an explanation and a couple of approaches to send a full precision float (e.g. 91.55) from an EZ-B using ARC scripting (JavaScript) to an Arduino without losing the value.
Problem
Right now, the EZ-B code uses:
This sends an array with one element (the JavaScript number) that isn’t automatically broken down into its full 4-byte IEEE 754 float representation. On the Arduino side, your code is reading only one byte, so it isn’t capturing the whole value.
Two Common Solutions
  1. Send as a String (ASCII) and Parse on Arduino
In this approach you convert the float into a string and send that. On the Arduino, you can use functions like Serial.parseFloat() or Serial.readStringUntil() to convert back to a float.
EZ-B JavaScript Example: js var actualCourse = 91.55; // Optionally send a header character to help with framing, e.g., 'A' UART.hardwareUartWrite(0, "A" + actualCourse.toString() + "\n");
Arduino C++ Example: cpp float actualCourse; void setup(){ Serial3.begin(9600); // Communication with EZ-B Serial.begin(9600); // Debugging via Serial Monitor } void loop(){ // Wait until a full line is received if (Serial3.available()){ String data = Serial3.readStringUntil('\n'); // Read until newline // Optionally check for header 'A' int idx = data.indexOf('A'); if(idx != -1){ String numStr = data.substring(idx+1); actualCourse = numStr.toFloat(); Serial.print("actualCourse: "); Serial.println(actualCourse); } } }
Pros: Simpler debugging (you see the ASCII data), no worry about platform-specific binary formats.
Cons: More overhead in terms of bytes sent and a bit slower parsing.
  1. Send as Binary (Typed Array) and Reconstruct on Arduino
Convert the float into its binary representation (4 bytes) on the EZ-B, then on the Arduino read all 4 bytes into a float variable using a union or memcpy.
EZ-B JavaScript Example: js // Convert a float to 4 bytes using typed arrays var actualCourse = 91.55; var buffer = new ArrayBuffer(4); var floatView = new Float32Array(buffer); floatView[0] = actualCourse; var byteView = new Uint8Array(buffer); // Optionally send a header byte for framing (for example 65 which is 'A') var header = [65]; // Convert the typed array to a regular array of numbers var dataBytes = Array.from(byteView); UART.hardwareUartWrite(0, header.concat(dataBytes));
Arduino C++ Example: cpp float actualCourse; union { byte b[4]; float f; } dataUnion; void setup(){ Serial3.begin(9600); // EZ-B communication Serial.begin(9600); // Debugging } void loop(){ // Wait until at least 5 bytes (1 header + 4 data bytes) are available if (Serial3.available() >= 5) { if (Serial3.read() == 'A') { // Check for header byte // Read the next 4 bytes into the union for (int i = 0; i < 4; i++) { while (Serial3.available() == 0) ; // Wait for byte dataUnion.b[i] = Serial3.read(); } actualCourse = dataUnion.f; Serial.print("actualCourse: "); Serial.println(actualCourse); } } }
Pros: Sends the data in a compact 4-byte form without conversion overhead.
Cons: Requires careful attention to endianness (most EZ-B systems and Arduinos use little-endian) and framing to ensure you’re reading the correct bytes.
Recommendation
If precision and speed are critical (and you can guarantee the same binary format on both sides), then using the binary approach is best.
If you prefer simplicity and easier debugging (at the expense of a few extra bytes and parsing overhead), the string method is a good approach.
Follow-up
Let me know if you need help with:
  • Adjusting the header/framing process
  • Using union vs. memcpy on the Arduino side
  • Debug logging on either side to ensure the full value is received
Feel free to ask for further assistance or additional examples.
Hello @Athena, Can you please send the "Binary Approach"(2nd option) in a form that I can cut and paste for the JavaScript and C++? Thank you so much. Jack
Below are the complete cutandpaste code examples for the binary approach. The JavaScript code converts the float into four bytes (using a TypedArray) with a header byte, and the Arduino C++ code reads the header and then the four bytes into a union to reassemble the float.
EZ-B JavaScript Code
// Initialize UART on port 0 at 9600 baud
// Define your float value
// Create an ArrayBuffer to hold 4 bytes (32-bit float)
floatView[0] = actualCourse;  // Store the float value
// Get the underlying bytes from the ArrayBuffer
// Optional: add a header byte (e.g., 65, which is the ASCII code for 'A')
var header = [65];
// Combine header and data bytes into one array
Arduino C++ Code
float actualCourse;  // Variable to store the received float
// Use a union to convert 4 bytes into a float
union {
  byte b[4];
  float f;
} dataUnion;
void setup() {
  Serial3.begin(9600);  // Communication with the EZ-B
void loop() {
  // Ensure at least 5 bytes are available: 1 header byte + 4 data bytes
    // Read header byte and check for the expected value (65)
    if (Serial3.read() == 65) {
      // Read the next 4 bytes and store them in the union array
        while (Serial3.available() == 0);  // Wait for byte
      // Retrieve the float value
      // Print for debugging
Explanation
  1. JavaScript Side:
    • We create a 4byte buffer and use a Float32Array view to store our float.
    • A corresponding Uint8Array view allows us to extract the individual bytes.
    • A header byte (65, you can change this if needed) is prepended to help frame the data when reading on the Arduino.
  2. Arduino Side:
    • We wait until at least 5 bytes are available on Serial3.
    • The header byte is checked to ensure proper synchronization.
    • The four following bytes are read into a union, which reassembles the bytes into the original float.
Feel free to ask if you need any further adjustments or additional help with framing or debugging!
#4   — Edited
@athena, is it easier to send the value multiplied by 100 or 1000 into an int32 and then reverse the multiplication on the Arduino side? This is because the float may not be interpreted the same on Arduino as the float from Arc's JavaScript.
ARC uses Jint. Jint focuses on being spec-compliant with ECMAScript 5.1 and selectively implements ES6+ features-but binary data buffers like ArrayBuffer and TypedArray are not supported by default.
Below is one effective workaround-multiplying your float by 100 (or 1000) to convert it into a 32bit integer and then sending that integer’s bytes. On the Arduino side you simply reverse the scaling to recover your original value. This approach can be easier when working with ARC’s JavaScript engine (Jint), which may not support binary data buffers (ArrayBuffer/TypedArray) by default.
Below are complete cutandpaste examples.
EZB JavaScript Code
In this example, we multiply the float by 100, convert it into an integer, and then split that integer into 4 bytes using bitwise operators:
// Define your float value and scale it (here, using 100 for two decimals)
var scaledValue = Math.round(actualCourse * 100); // becomes 9155
// Break the 32-bit integer into 4 separate bytes
var byte0 = scaledValue & 0xFF;
var byte1 = (scaledValue >> 8) & 0xFF;
var byte2 = (scaledValue >> 16) & 0xFF;
var byte3 = (scaledValue >> 24) & 0xFF;
// Optional header byte for framing (for example: 65 which is 'A')
var header = [65];
// Send header plus the 4 bytes
UART.hardwareUartWrite(0, header.concat([byte0, byte1, byte2, byte3]));
Arduino C++ Code
The Arduino code waits until it receives at least 5 bytes (1 header + 4 data bytes), then reconstructs the integer and reverses the scaling to obtain the original float:
#include <Arduino.h>
float actualCourse;  // Reconstructed float value
int32_t scaledValue; // Scaled integer value
void setup() {
void loop() {
  // Ensure at least 5 bytes are available: 1 header + 4 data bytes
    if (Serial3.read() == 65) {  // Check for header byte (65 = 'A')
      // Read the next 4 bytes to reconstruct the 32-bit integer
      scaledValue = 0;
        while (Serial3.available() == 0);  // Wait for each byte
        scaledValue |= ((int32_t)Serial3.read() & 0xFF) << (8 * i);
      // Reverse the scaling (dividing by 100.0 to get back the float)
      actualCourse = scaledValue / 100.0;
Explanation
  1. On the EZB Side (JavaScript):
    The float value is multiplied by 100 and rounded to form an integer (e.g. 91.55 becomes 9155).
    The integer is split into 4 bytes using bitwise shifts and masks.
    A header byte (here, 65) is prepended for framing purposes so the Arduino knows where the data begins.
    The byte array is sent over UART.
  2. On the Arduino Side (C++):
    The code waits until 5 bytes are available.
    It checks the header byte, then reads the next 4 bytes.
    The 4 bytes are reassembled into an int32_t using bit shifting.
    Finally, the integer is divided by 100.0 to recover the original float value.
This method sidesteps the need for ArrayBuffer/TypedArray support and ensures that both sides interpret the scaled number consistently.
Feel free to ask if you need further adjustments or additional help!
#6   — Edited
Rewrite that but don’t use a for loop in the arduino read section so it’s easier for robojack to understand the code. Rebuild the int32 inline
Hello @Athena, Thank you for your help.  Could you please rewrite the code using the recommendation from DJ in the previous post? Thanks. Jack
Below is an updated solution that avoids the use of a for loop. The JavaScript side multiplies the float by 100, splits the scaled integer into four bytes, and sends a header plus the bytes. On the Arduino side, each byte is read individually and then reassembled inline into an int32_t without a loop.
// Define your float value and scale it (using 100 for two decimals)
var scaledValue = Math.round(actualCourse * 100); // -> 9155
// Break the 32-bit integer into 4 separate bytes using bitwise operators
// Optional header byte for framing (for example: 65 which is ASCII 'A')
var header = [65];
// Combine the header with the 4 bytes and send via UART
Arduino C++ Code
int32_t scaledValue;         // Scaled integer value received
void setup() {
void loop() {
    // Read and check the header byte (expected to be 65)
      // Read each data byte individually (wait for each byte if needed)
      while (Serial3.available() < 4);  // Wait until 4 bytes are available
      int32_t b0 = Serial3.read();
      int32_t b1 = Serial3.read();
      int32_t b2 = Serial3.read();
      int32_t b3 = Serial3.read();
      // Rebuild the scaled integer inline without a loop
      scaledValue = (b0 & 0xFF) |
                    ((b1 & 0xFF) << 8) |
                    ((b2 & 0xFF) << 16) |
                    ((b3 & 0xFF) << 24);
      // Reverse the scaling to obtain the original float value
      // Print the result for debugging
Explanation
  1. EZ-B JavaScript:
    • Multiplies the float value by 100 (to preserve two decimal places) and rounds it to form an integer.
    • Uses bitwise operations to extract each byte from the 32-bit integer.
    • A header byte (65) is added to help the Arduino synchronize the start of the data transmission.
    • The concatenated array is sent via UART.
  2. Arduino C++:
    • Waits until at least five bytes are available (one header byte and four data bytes).
    • It verifies the header byte, then reads four bytes individually.
    • Reassembles the 32-bit integer inline without a loop using bit shifting.
    • Divides the reconstructed integer by 100.0 to recover the original float.
    • Outputs the result on the Serial Monitor for debugging.
Feel free to ask if you have any additional questions or need further clarification!
