Get Line Containing From Array icon Get Line Containing From Array — Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches. Try it →
Script Help For Custom Http Server Missing A Command
DJ, I just wanted to give you a heads up that the "ControlCommand("HTTP Custom Server", StartServer)" command is missing from the EZ-Script Functions manual in the Script Help section.
Currently it shows the following. Custom HTTP Server ControlCommand("HTTP Custom Server", StopServer) ControlCommand("HTTP Custom Server", ScriptStart)
Not being picky, Just letting you know so you will know:)
Eww, yes, I would need a way to script the starting too!
The command is in the application, just not in the help text. I guessed based on the StopServer text. It didn't take but about 2 seconds to figure out but, just thought I would let DJ know.
Fixed in next release - thanks!
