Sayezb Does Not Work With Surface Pro
Hi DJ,
I changed my platform to Microsoft surface pro recently. I don't know why the sayezb script does not work with ez-b. Even updated and re-install!
And I have already doubled checked within that forum, but I found nothing to mention about this!
Do you have any ideas be able to solve this issue?
Thanks a lot
  1. Regards Ricky Ma
Hi all,
I made threads in these few days, as below:
Thread 1) Aimlbot Setting -> This topic was finished.
Thread 2) Sayezb Does Not Work With Surface Pro (for Technical Assistant) -> This one is my fault. I typed the wrong subject and can’t modify because it is no "Subject Edit" function on forum.
So, I made a new thread for Open Conversational as "Sayezb does not work" (Thread 3).
Thread 3) Sayezb does not work -> This one has been deleted.
Thread 4) Trouble with the program -> This one is talking about the servo goes to wrong angle. But why this one has been deleted as well?
@DJ, I apologise that I don't know that forum has terms between technical assistant and open conversational under same topic. I misunderstand that is between internal and public!
Hope @Justin and @Patrick please don’t mind, I grouped the "talking function (Sayezb)" and "servo with program" these two topics into one thread. If both are ok, I will keep continuing to discuss over there.
Actually, there is no any script program for learning for 40 years ago. I would like to make and finish my childhood dream for robot making. So I start to learn how to write script within these two years. My knowledge of this field just in basic level. Hope all experts could forgive and understand! By the way, "ez-b" is great product for starters, but these two years this knowledge is going very fast and complicate. I love to learn more in person if any course at EZ-Robot in Calgary, I am willing to fly come for learning!
  1. Regards Ricky Ma
hi ricky ma
so all comes here now?
Hi Patrick,
Yes, if you don't mind:D and thanks for your help!
ok thats good for me.did you calibrate all servo's as in video?
Hi Justin,
Thanks for your video:)
I followed your instruction twice, but the problem is still here. Pls. see my video as below:
no need to reboot after set all ports to 90,just save. do not connect the wire from servo before hit the set all ports to 90. also use connection 0,your servo is not set to 90 cause green led of ezbv is stil flikkering,so its not connected to ARC.also you need to adjust the screen resolution,to be able to see the save button.
1 connect ezb 2 go to web page 3 set all ports to 90 4connect wire 5get the wire out 6do all 18 servo's 7then save (do not reboot)
#15
Hi Patrick,
I tried to your instruction again. I found out the problems that I used connection 0 could become normally in Client Mode (WiFi mode). But to use connection 1 in client mode, the trouble problem is appeared!
Pls. see the below pictures & video for your reference:
good find.indeed you calibrated on connection 1,so if you used connection 0 it will be different.best is to use connection0. your servo is not an original ezb servo.each servo has its own adres and so on.
best for now is to set your screen resolution,so you can see the save button. then we do all over again but with connection0 can you make screenchot from the webpage ?
