Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
France
Roli H-bridge Question Too
Roli H-Bridge Question Too
Hi,
I have a probleme with my Roli h-bridge.
I checked my connections like explained in those posts : https://synthiam.com/Tutorials/Lesson/44 https://synthiam.com/Community/Questions/6809&page=2
My h-bridge was initially connected like the wrong way as here :
Now when I open the exemple project from roli in ARC , if I want to go forward, only the right motor is going forward (nok), if I want to go right, only right motor is going backward (nok), if I want to go backward, the two motors are going backward (ok), if I want go left, left motor is going backard, right motor is going forward (ok).
I don't know where is my mistake.
Thanks
Did you set the pwm speed?
Modifying the project did you accidentally miss the speed initialization script for the hbridge in the connection control?
France
here is the init script :
# This is the initialization script for your Roli robot
# This script is called from the Connection Control when a connection
# is made to the Roli EZ-B
# Move the servos into the calibration position
# All servos will be set to 90 degrees
ControlCommand("Auto Position", AutoPositionFrameJump, "Calibrate")
# Pause for a brief period of time to ensure the servos have been initialized
sleep(500)
# We want the arm and neck servos to move smoothly
# To do this, we will set the speed of each servo
# The speed is how quickly a servo will move between positions
# We set a variable for the speed, and then use that variable for
# every speed command.
# This is an effecient way to reuse a value numerous times
$speed = 1
servospeed(d12, $speed)
servospeed(d13, $speed)
servospeed(d14, $speed)
servospeed(d15, $speed)
servospeed(d16, $speed)
servospeed(d17, $speed)
servospeed(d18, $speed)
servospeed(d19, $speed)
# This sets the speed for the HBridge Motor Controller
# The speed is a number between 0 and 255
# Setting this speed will initialize the PWM on the motor controller
SetSpeed(255)
# Even though we set the speed, we will also enable the PWM
# on the speed pins that connect to the HBridge Motor Controller
# The number is 100, which means 100%
pwm(d0, 100)
pwm(d5, 100)
France
Hello,
Sorry, I did not have time to see my problem.
Maybe I could during the Christmas holiday;)
