is there a way to replace bluetooth with usb cable
Community Robot Questions Replace Bluetooth With Usb Cable bborastero Gibraltar Asked Jun 2012 — Edited Dec 2012 Replace Bluetooth With Usb Cable Skip to comments Jump to end is there a way to replace bluetooth with usb cable Jump to end Upgrade to ARC Pro Don't limit your robot's potential – subscribe to ARC Pro and transform it into a dynamic, intelligent machine. Compare Pro Features View Subscription Plans DJ Sures PRO Synthiam #1 Jun 2012 If you use a TTL usb adapter, yup Connect the RX and TX lines off the TTL usb adapter to the EZ-B plug and voila bborastero Gibraltar #2 Jun 2012 Excuse my ignorance Will EZ B still connect to ARC for programing i want my bot to be autominous so i don't mind not having BT control over it Niek Netherlands #3 Jun 2012 Yes, My omnibot has a USB->TTL adapter i got from SparkFun and it works just like the Bluetooth. bborastero Gibraltar #4 Jun 2012 hay niek could you give me link please bborastero Gibraltar #5 Jun 2012 Got rx/tx connected to usb, soild LED, could you tell me how to find com ports in windows xp or what to do to connect to ARC Niek Netherlands #6 Jun 2012 Go to Start menu -> Devices and printers. At the bottom, you should see a 'USB COM port (COM...)' rgordon USA #7 Oct 2012 Niek ----What is the part number or link for the USB->TTL adapter you got from Sparkfun? Do you need to also hook up the USB->TTL adapter GND to the EZ-B GND? Or are you only using the Tx and Rx? rgordon USA #8 Oct 2012 bump 1 2 » »» Login to post a comment
bump
