EZ-Script Console icon EZ-Script Console — Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN. Try it →
Question With 2Nd Ezb Purchased
My first one worked great. Actually, it is the ARC I am having trouble with. I create my ports and save them in two places. When I call them back, it does not have all of the ports. Also, my connection can only be established in ARC. I have tried to MERGE with my programs after I have connected. But the whole thing is kinda squirrelly. so, I figured I would make mention of it.
Thanks
When I tried to use the movement panel, it gave me an exception error repeatedly.
Oh, it should work... Was it a pop up dialogue with the continue, cancel etc. buttons on it?
You can use the custom movement panel, I used it for testbot since he had to drive 2 modified servos per side so 4 in total. Just use the script commands Move() with relevant ports and directions for each direction, ignore speed.
I will try them without setting up the motors first individually. I will try the Movement Panel by itself.
I will let you know.
Well, it did not work. I tried to post the message it gave, but it would not let me post.
I'm not home at the moment so can't do it yet but if you let me know which ports do which modified servos I'll try adding the panel and pop it on the cloud for you. I wont get chance for another 4 hours though.
Right motor is D19, Left motor is D18. It works when I set them up individually. But, when I save them, I loose most of the 20+windows I have setup. Movement Panel does say continue. But, gives me an error.
Thanks,
Mel
#15
I just posted BOBII in showcase section.
#16
OK, so I changed all of the ports to match the Boxrobot example. Still doesn't work. It says disconnected.
