Is it possible to print out a complete six robot. I guess I mean is there a complete set of stl files to do so? Thanks.
Chris
Task Script
— Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
Chris
Of course.... you just need to look in the 3D printing section on here...
Yes sir. I only find the top and feet though. I went over to thingiverse and found it all. Thanks again.
Chris
We've made it very easy and placed the files in many locations to be impossible to miss
As Richard said, you can click on the 3d printing button at the top of community section and access ALL the parts.
Otherwise, you can view the PRODUCTS section and select the robot that you're interested in. There is a tab on EVERY robot product page titled CAD FILES. You will find the stl files per robot in that respective tab.
Load ARC and load the robot project that you wish to print. There are buttons to view the assembly instructions. Press the INSTRUCTIONS button in ARC and the stl files are all visible, including buttons to print directly from the ARC software with your selected printer software
Lastly, the files can be obtained by thingiverse as you discovered.
