TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
Resolved Resolved by Rich!
Parallax Hb 250 Motor Controller And Ez-b V4 Microcontroller
Parallax Hb 250 Motor Controller And Ez-B V4 Microcontroller
I am trying to run two Parallax HB 25 motor controllers and Parallax Motor Mount and Wheel Kit 28962 with an EZ-B v4 micro-controller. The HB 25 data sheet says that the motor controller needs a standard pwm servo signal to operate. I am using a regulated 7.2 vdc for EZ-B and 12 vdc for motors. When I hook it up to a standard servo it works and when I hook it up to the motor controllers it doesn't. I have tried everything I can think of to get it EZ-Bo work to no avail. Help
Also the Motor Mount and Wheel Kit comes with a encoder to establish position. Can the EZ-B use this information. If yes what do I need to do.
#17
Something similar to the script I made for Gwen's B9's movement will work. Have a read of this topic and the project I posted in there.
While it's written for the sabertooth you can easily change the SendSerial() commands for Servo() commands.
