Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
Have you added anything to the project lately?
My first thoughts are it's an issue with the wallpaper (either the image itself or the way it's been implemented in to ARC). Does it happen if you remove the wallpaper (if that's possible - I haven't updated yet)
I did a little recodeing in the INT Script and started useing the script manager.
I did start useing my own wallpaper image. It's was in BMP format. However I did change over to a different image in .PNG and then one in .Jpg format and it still would not save without 1/2 dozen error messages. As soon as I get a free moment I'll reproduce the error and let you know the exact message wording and error code it gives.
Thanks, Dave
OK, below are the two different error messages I get with details and what happened to get them:
First I try to save and get the first error message box below appears that just says "Out of memory" with the details below. When I click the "continue" button the wallpaper disappears and all that is seen in the background behind my controls is white with a red X from corner to corner. Then another error box suddenly appears. That error message says "Generic error occurred in GDI+". When I click on that "continue" box I get another box just the same as the last. I will get this with t more "Continue" clicks of new error boxes and then everything runs good and I can save the project whenever I want. However the original wallpaper I installed is still missing. Later in the project after I've done more work this will all happen over again.
"Out of memory" First Error detail:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OutOfMemoryException: Out of memory.
   at System.Drawing.TextureBrush..ctor(Image image, WrapMode wrapMode)
   at System.Windows.Forms.ControlPaint.DrawBackgroundImage(Graphics g, Image backgroundImage, Color backColor, ImageLayout backgroundImageLayout, Rectangle bounds, Rectangle clipRect, Point scrollOffset, RightToLeft rightToLeft)
   at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle, Color backColor, Point scrollOffset)
   at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle)
   at System.Windows.Forms.Control.OnPaintBackground(PaintEventArgs pevent)
   at System.Windows.Forms.ScrollableControl.OnPaintBackground(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.OnPrint(PaintEventArgs e)
   at System.Windows.Forms.Control.WmPrintClient(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.UserControl.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.1008 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder
    Assembly Version: 2013.9.27.0
    Win32 Version: 2013.09.27.00
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/ARC.exe
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationCore
    Win32 Version: 4.0.30319.1015 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
EZ-RibbonMenu
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/EZ-RibbonMenu.DLL
EZ_B
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/EZ_B.DLL
System.Configuration
    Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
System.Xaml
    Win32 Version: 4.0.30319.298 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
FFMPEG
    Assembly Version: 2013.8.13.0
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/FFMPEG.DLL
yomnebzu
aForge
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/aForge.DLL
EZ-QRCode
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/EZ-QRCode.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
"Generic error occurred in GDI+" Second through fifth error message details:
System.Runtime.InteropServices.ExternalException (0x80004005): A generic error occurred in GDI+.
   at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttrs, DrawImageAbort callback, IntPtr callbackData)
   at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr)
mscorlib
EZ-Builder
System.Drawing
System
PresentationCore
WindowsBase
EZ-RibbonMenu
EZ_B
System.Xml
System.Speech
System.Xaml
FFMPEG
    Win32 Version:
yomnebzu
aForge
EZ-QRCode
enabled.
For example:
<configuration>
</configuration>
The latest download should be 10.3.13. The error message shows Assembly Version: 2013.9.27.0. I'd give 10.3 a try and see if your errors clear up.
Before I posted the last time I had uninstalled ARC, downloaded the latest version 10.3.13 (which I had been running) and reinstalled. Still same thing. Thanks for the suggestion though.
It seems tied into the Wallpaper feature and my project somehow. I had no problems with this release till I installed one of my own wallpaper images. I loaded ARC and my project onto another laptop and had the same issue. I started a new project and loaded a personal wallpaper and could not reproduce the error (although I didn't work with it for very long). So that may narrow it down to my project. I don't know what is in there that's giving me problems saving. Maybe next I'll try moving or deleting the project file I'm trying to replace and save a fresh one.
Stay Tuned...........
EDIT: I tried what I mentioned above but nothing changed.
Also, I cant seem to get rid of my personal wallpaper I installed. Is there a way to revert to the original EZ Robots wallpaper or not even use one at all? I tried un-checking the option in the Preference Menu "Use EZ Wallpaper" and it does remove the wallpaper. However each time I save and reopen my old wallpaper is still there.
i'm looking into it...
Holy Bitmap DJ! Your customer care and service are breathtaking. Thanks for putting in the long hours and taking care of this so fast. I was beginning to think it was me or my computer. can't wait to update and get back to programming.
