File Manager icon File Manager — Displays files currently open for reading by scripts, shows only read-opened files, helps diagnose read/write locks and file access errors. Try it →
Omnibot 2000 Pan/Tilt
Looking for ideas on a pan tilt setup without ordering brackets. I have 2 mg995 servos I plan on using. My biggest concern is keeping the neck to look stock and still have left/right, up/down function. Also there's no extra weight just lights and 2 servo extensions.
If you have the horns, you can glue the horn to the servo's side and just use hot melt glue. Glue the servo to a base of anything , and attach the camera or whatever to the other horn. It works good. Of course, I prefer the brackets because it looks better.
