Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Newb Question, Can I Edit Poses By Typing?
I am trying to edit poses, and only appear to be able to click and drag to change values for each servo. I want to just click and type values, but that has not worked.
Export and import gives me a work-around, but the rest of Builder is so user friendly I am hoping I am just missing something.
I go into auto position, click settings, then select or create a new frame. Example would be to create a mirror pose of FLY 2, needing 9 servo edits for just that frame.
Thanks for any advice you can offer.
FYI, I know this is a technical assistance question, but I don't want to get flagged or banned for misuse.
     La Machine!
Mirroring Frame
  1. Select the frame you wish to mirror
  2. Press NEW FRAME
EDITING There are two ways to edit.
  1. Use the Left mouse button to drag up/down
  2. Use the Right mouse button to open the dialog and use keyboard or mouse to select exact digit
I KNEW I had missed something basic again. Thanks for the help. That was exactly what I needed.
I expect to have my moves like Jagger soon!
Haha, that'a boy! looking forward to seeing them:D
Nice trick to get from 0 to 180, or vice versa is to do this..
  1. Right-Click on the angle selection box
  2. The drop down will be displayed
  3. Use the HOME or END or PAGE UP or PAGE DOWN buttons to skip
