Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
#41
Will this blaster also control the Neopixel Jewel? I'm want to use them in my R2D2's Holo Projectors. They have a very small footprint and it will be great to have them change colors with his mood.
Any idea when they will be available to purchase? I have 3 Jewels to connect. I just got back from Droidcon4 and people were amazed at the speed of my dome servos. Apparently the EZB is much faster than their traditional setups. They were all gathering around my iPhone watching my "freak out wave" script for my 10 dome panels. Thanks DJ!
Sincerely,
Doug
The Freak Out Wave.... https://www.youtube.com/watch?v=1-VcY6Z_IaY
#42
Hi Doug! Pretty sure it will work - all neo pixels should use the same protocol.
The first article production samples should be in our hands in 3 weeks or so right off the press. On the website a few weeks after that
#43
Wow, that was wild. It freaked me out. Would you mind posting your code for that? Just wondering what type of motor you've using to open and close the doors. Servos? Are they directly connected to the EZB or do you a servo control board or other control device?
#45
Ah, nice. Your using the Auto Position control for the freakout. Did you have to play with the delay and steps to get the wave right?
#46
I increased the steps but left the delay alone. I also left the speed at -1 for the fastest travel. Beginner's luck, I guess. lol
#48
-1 means "use last speed specified"
so if you use -1 everywhere, unless the speed will actually be 0 because -1 means don't change the speed.
