Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
Need Help With Plugin
I need some help with a plugin I am working on. I am new to C# and OOP. Have went thru the Tutorial and the SDK Tutorials also.
How do I get the values from the form in to my C# code?
 public enum LocationType
                Wall = 255,
                Empty = 0,
                Destination = 254,
                Source = 1
            public struct Location
instead of Wall = 255, how do I get Wall = textBox1.Text. textBox1 being the Textbox name.
Thanks RichardZ
//Option1:
//  null        => 0 AND returns false
//  empty       => 0 AND returns false
//  non integer => 0 AND returns false
int i1;
if (!int.TryParse(textBox1.Text, out i1))
    //it's not an integer
    //raise an error
//Option2:
//  null        => 0
//  empty       => raises an exception
//  non integer => raises an exception
int i2 = Convert.ToInt32(textBox1.Text);
//Option2:
//  null        => raises an exception
int i3 = int.Parse(textBox1.Text);
If you're collecting input from a user, I'd go with option #1
Thank you ptp, I have decided to leave the values for Robot, Empty, Wall and Goal as set values. Having them as part of an enumeration is my problem there I think.
In the picture I posted, Map Variable is $MyMap. This is a string of 6400 characters. Each character represents a 1'x1' block. How do I get this variable from ARC into my C#? I plan to use 2 for loops to move the data from the $MyMap variable to a 2 dimension array in the plugin.
private void DoSomething()
	//Get EZScript's map variable
	var mapString = VariableManager.GetVariable("$MyMap");
	//example map 4 x 3 => "X....X....X."
	//Convert string to an array of 4 by 3
	var map4X3 = StringToMap(mapString, 4);
	DoSomethingWithMap(map4X3);
	//Convert array to string
	var newMapString = MapToString(map4X3);
	//Set EZScript's map variable
	VariableManager.SetVariable("$MyMap", newMapString);
private void DoSomethingWithMap(char[,] map)
	for (var rowIndex = 0; rowIndex < map.GetLength(0); rowIndex++)
		for (var colIndex = 0; colIndex < map.GetLength(1); colIndex++)
			var cellValue = map[rowIndex, colIndex];
			//DoSomething with cellValue
private static string MapToString(char[,] map)
	return new string(map.Cast<char>().ToArray());
private static char[,] StringToMap(string flatString, int width)
	var flatArray = flatString.ToCharArray();
	var height = (int)Math.Ceiling(flatArray.Length / (double)width);
	var result = new char[height, width];
	for (var index = 0; index < flatArray.Length; index++)
		var rowIndex = index / width;
		var colIndex = index % width;
		result[rowIndex, colIndex] = flatArray[index];
	return result;
If your wall value is an enum you should use a ComboBox to capture the user input.
To load the ComboBox LocationTypeComboBox:
LocationTypeComboBox.DataSource = Enum.GetValues(typeof(LocationType));
LocationTypeComboBox.SelectedIndex = 0;
To get the enum from the ComboBox:
LocationType locationType;
Enum.TryParse<LocationType>(LocationTypeComboBox.SelectedValue.ToString(), out locationType);
The "Standard" for a Label and Input is: Label TextBox Label ComboBox ...
Thank you I believe this is what I was missing. I have picked up a few books on C# and going thru the lessons. catching on to the syntax easy enough but some of the concepts are a bit tough to get my head around. It is a bit different from TRS-80 Basic.
When I execute the plugin, I get an error:
An exception of type 'System.Exception' occurred in ARC.exe but was not handled in user code
Additional information: Variable is an array: $MyMap
Makes sense to me. in ARC $MyMap is an array of 6400
the line of code reads:
You mentioned a string.
if your variable is an Array:
//Get value from position 0 of $MyMap array
VariableManager.GetVariable("$MyMap", 0)
I'm curious, what you plan to do with EZ-Script and an Array of 80x80 i.e. 6400 positions ?
