Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
  1. What project are you loading?
  2. Have you connected to the EZ-B v4 by pressing the Connect button?
  3. Does the EZ-B v4 make the connection sound? Consult this video to hear what the connection sound is: Connection Tutorial
Singapore
Thank you so much for that fast respond but Hmm i think i understand ill try and get back to you if i am still in doubt!
Watch this video starting at 4:00
FYI, please create more descriptive subjects when posting. "Need Help" is quite vague:)
Singapore
Alright sorry may i know if the way i assembly is wrong or? its walking movement isnt stable it will fall down whenever it start to walk and its starting position is also wierd
Which robot are you using? Have you followed the calibration tutorial and calibrated the servos? Have you fine tuned the servos that still required it after calibration? Are you using the latest version of ARC and loading the latest Example Project for the robot you are using? Have you made any changes to the example project?
Those are just a few questions off the top of my head which require answers before we can really help.
Singapore
JD, yes i have calibrated it and for now the left and right shoulder have some issues like the waving part the position is like this
and the walking part is also wobbly not stable enough for a few steps There is also a loud buzz sound when i connect to the ip address, is it normal?
Thanks so much for your help!
Nice pic of JD!:D
Looks like you need to calibrate the shoulders - can you please follow the tutorials on the course page? There are many Lessons that are recommended to follow and become a robot expert:D
Here's a link to the shoulder calibrate lesson: CLICK ME
As for the other lessons, please visit the LEARN section by pressing the LEARN button from the top of this website
Singapore
Thanks for the reply and i have already calibrated the shoulder and twice to be sure. I also did follow the tutorial:( What about the sound coming out from the back of the robot body?
