Resolved Resolved by robo rad!
My EZ-B v4/2 Wi-F has steady blue light and say connection error
My EZ-B V4/2 Wi-F Has Steady Blue Light And Say Connection Error
My EZ-B v4/2 Wi-F has steady blue light and say connection error.  Tried reset button but it does not do anything.  I do not have anything connected to the EZB v4/2.  Does anyone know the reason why?
I am using the current free version of ARC.
Thanks in advance.  PS, I hope to be getting a member subscription hopefully by April.
Cheers.
Ya that happened to me too last week,on testing it is the bottom board with the sound that is blown ,I can only get a flashing blue light and will connect to the server still but on software it keeps disconnecting after 3 seconds with error message.No more sound either. If you still get sound then it could be your top board the Comm board.
Hi Robo Rad.  Funny thing is it happened to two of my EZB v4/2.  I got my old top EZB v4 and it now works.  I wish i knew what happened and why it did that.
Now my question is can I use the current Free ARC Firmware on the EZB v4?
Thanks for you answer Robo Rad.
Cheers
Thanks Robo Rad, using the old EZB v4 worked.  And the new firmware is only for EZB v4/2.  Going to open a new question if it we work with the new Free ARC.
Cheers
Hello all,  Can I use the EZB v4 with the current free ARC?
Thanks in advance.
#6   — Edited
Thanks Dave.  I am able to get the blue light blinking and I can connect  with Wi-Fi of the EZB v4 in the current free ARC. However, I cannot get to the web page to change it to client mode, it say connection unamiable.  I have also reset the EZB v4.  Any thoughts?
Thanks and cheers
Edited: Here is the current firmware:   EZ-B v4.x/1 Native Firmware ID: 31-53-0-0-47-255-58-57-56-37-37-38 Setting battery monitor voltage: 7 Setting battery protection: True Setting i2c rate: 100000 EZ-B voltage is 6.488889120 EZ-B temperature is 24.33952776160016496C Connected
Twitter
#8   — Edited
Hi Merne,
You went to https://192.168.1.1 and nothing after you connected to the EZ-B network ? I assume you are running windows so if you go to cmd prompt and type ipconfig what is your IP address and default gateway? Can you ping the EZ-B ping 192.168.1.1
BTW Did you try disable firewall and antivirus ?
Edit: scrolling back up I see you edited comment and can connect with ARC ?? so what was the IP address in ARC ?
