My 3d Design For The New Io Tiny Board
My 3D Design For The New Io Tiny Board
This is just a simple mock up... I am sure it will need tweaking. I designed it according to the board dimensions that @Jeremine posted in another thread ( https://synthiam.com/Community/Questions/9378 )... Since I actually don't have an IoTiny to work from, I am sure (as mentioned) I will need to adjust the design a fair bit... Io_Tiny_BetaV4_part1.stl Io_Tiny_BetaV4_part2.stl
#17
@ANDY ROID.... I am waiting for mine as well so the design I uploaded in post 12 is the most recent. This is until I get my ioTinys then I will see if anything else needs to be tweaked...
#18
Hi Richard,
Thanks for the update. Mine are on the way too. Your design is really nice and fits me needs.
Ron
#19
So awesome! Im late to the game and didnt know the IO Tiny existed when I wanted a smaller version EZb!:) I just ordered one. Thanx so much for designing this sweet case for it!
#20
Hi Richard, Did you ever make the final design with the post hole? I haven't searched anywhere else in the forum for the .stl's. Just curious. I am planning a new project which, using a case for protection is a good idea, and wanted the final case design.
Thanks for sharing the case .stl's
#21
Thanx so much! I printed one for mine. BTW, what size screws do I need for this?
#22
I don't know the exact size but you can use the screws that come inside servo hardware baggies.
#23
@RR333 As Jeremie suggested you can use the screws that come with servos... I use a bit of double sided tape or foam under the ioTiny to secure it and then just gluing the case together... I use abs so a bit of acetone glues it together great...
#24
cool. Mine seems to almost snap together fine so the servo screws should be fine. Thanx!:)~
