Movement Pannel In Vb Express 8
hi all i have a form with a connect panel working ok i have Movement Panel and want to know how to assign ports to it can anyone help with the code needed?
 Private Sub EzMovement1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles EzMovement1.Load
        EzB_Connect1
        EZB.Movement.ServoWheelLeftModifiedPort(EZ_B.Servo.ServoPortEnum.D10)
    End Sub
Netherlands
you can assign the port like you did :
the d10 is the port on your ezb
hi i get error
Warning 1 Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated.
Error 2 Expression is not a method.
 With EzB_Connect1
            .EZB.Movement.ServoWheelRightModifiedPort(EZ_B.Servo.ServoPortEnum.D5)
        End With
Netherlands
hi there baloo,
did you do it on this way ?
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        EzB_Connect1.EZB.Movement.ServoWheelLeftModifiedPort = EZ_B.Servo.ServoPortEnum.D0
        EzB_Connect1.EZB.Movement.ServoWheelRightModifiedPort = EZ_B.Servo.ServoPortEnum.D1
        EzB_Connect1.EZB.Movement.MovementType = EZ_B.Movement.MovementTypeEnum.ModifiedServo
End Sub
and then the buttons
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        EzB_Connect1.EZB.Movement.GoForward()
    End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        EzB_Connect1.EZB.Movement.GoLeft()
    End Sub
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
        EzB_Connect1.EZB.Movement.GoRight()
    End Sub
    Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
        EzB_Connect1.EZB.Movement.GoStop()
    End Sub
First you define everything and than use them:)
hi i will try it when i get out of hospital( i had a heart attack ) :)
Netherlands
Ohh, ok, take it easy, take your time, if you need help with programming. I'm not a star but every little bit helps
hi i got this to work
EzB_Connect1.EZB.Movement.ServoWheelLeftModifiedPort = EZ_B.Servo.ServoPortEnum.D10
EzB_Connect1.EZB.Movement.ServoWheelRightModifiedPort = EZ_B.Servo.ServoPortEnum.D11
but not the 5 button's on the movement pannel
Netherlands
can you attach your code so i can have look.
so i see you have your wheels on d10 and d11
if you want i can make a little example for you if you give your ports and equipment.
hi i just have a form with a connect panel and movement panel i can assign motors see post #7 but when clicking on and button on the movement nothing happens i try to unload my project(zip)
