Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Mobile Say Command
I have been using the "SAY" command in a few of my subroutines. Since I updated my ARC version this week however, I've noticed that the SAY command no longer works on my Mobile, unless I've done something else wrong, as I'm continually trying to add more functionality to my robot.
When my code comes to the SAY command when I'm running my robot from my PC however, it works. It only doesn't work when I'm connected to my tablet, and the same programs worked last week. And yes, the volume is turned on my tablet, and it will make other sounds not emanating from EZB.
Has anybody else experienced this as of this week, or am I overlooking some other setting in EZB that I accidentally changed?
Richard R, I think that might have come our of WBS's HTML parsing project. "<p>" is an HTML paragraph break, so if you are trying to convert HTML to a TTS string, and it breaks TTS, it needs to be stripped out.
@thetechguru Correct. I mentioned it because there might be other characters or character sequences that could cause problems as yet unknown. Including characters that would not be visible normally (control characters).
And no, the HTML project is concerned only with stripping out characters and character sequences that cause the scripts to crash due to bugs in the script language (Backslash+quote, Left paren.,capital E followed by a number). And, of course quote marks themselves, but that's not really a bug. Then there is the amp part of &amp. Things like that. The rest get removed by the SubString function when extracting the desired data from the scrubbed text. The <p> got in by mistake and caused some lost time trying to figure why there was suddenly no speech being heard. I saw it in there but didn't think anything of it. It took a while to finally determine that it was the cause of the problem.
Plus I found it very strange that the <p> sequence actually had an effect on the speaking in the first place. Especially the fact that it didn't matter where in the string the <p> was. Makes me wonder if, whatever the algorithm is, it responds to other things. I tried some other common HTML sequences but nothing. In fact it didn't even speak them. It just seemed to ignore them. That makes me think it knows about HTML control character sequences and is set to self filter them unless it is something it recognizes. If so, what else does it recognize?
Now all I need to do is think of a way to exploit this oddity. Streaming on-off control?
