Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Microsoft Cognitive Speech - Text To Speech
Hello y'all, I've created a C# project and I'm already able to do basically the same as the Bing Speech Recognition plugin does, but I also need to make my EZ-B (JD) "speaks" in another language. I've installed a Microsoft voice, but that's a pretty bad one, and the Azure platform offers two very nice voices to be used.
Right now I'm stuck with how I send the voice received from Azure to the EZ-B. Azure offers a variety of audio formats.
Has anyone tried this before? I've gone through some of the tutorials in the SDK but couldn't find one that does something like that.
Thanks! Gilvan
Thanks @Mickey666Maus, that sounds great. But my question is on how to send the audio received to the EZ-B. I guess I'd have the same problem there.
@Gilvan,
Check the UniversalBot code https://synthiam.com/Products/ARC
Browsing the code you have information needed to send the sound data to EZB.
I've done that before, but i can't find the code.
This is related to the Microsoft Cognitive API, maybe DJ is working or will be working to support that feature too.
@DJ ?
@Mickey666Maus,
The api you mentioned
javascript example code:
var speech = new SpeechSynthesisUtterance('Ola Brazil!');
speech.lang = 'pt-BR';
window.speechSynthesis.speak(speech);
is only supported within the browser (not all) although chrome handles pretty well.
some complains: https://ejb.github.io/2015/06/07/html5-speech-synthesis-api.html
even if you manage to launch the chrome engine (v8) like ARC does with blocky editor, you don't have a way to extract the voice sound.
https://stackoverflow.com/questions/21905583/record-html5-speechsynthesisutterance-generated-speech-to-file
Still a neat idea for the web...
@ptp the api works quiet well...and to me it is kind of a good work around to get different voices and languages going. But you are totally right, it is only working from within a browser, so I was kind of pointing to the wrong direction I guess!
This is a working example of a web based client! Which can also send data over to ARC, but cannot be called from within ARC!
https://www.downtown-tattoo.de/robotics/test123.html
To connect to the ARCs server you would just have to make an XMLHttpRequest(); to call eg a ControlCommand() in ARC...
But the limitation is clearly that ARC cannot send data to the browser I guess? At least I did not find a solution on this!:)
