Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Meet The Smart Saltwater Aquarium Powered By Ez Robot
Ez Robot community I wanted to introduce my latest application of this system. Some members hear already know I keep two salt water aquariums one coral which unfortunately died off and my predator tank. Sea life needs delicate balance maintained in their little ecosystem. Things like light spectrum , temperature, ph balance , current of water , nitrate and ammonia levels and calcium levels. These things take a practiced hand to maintain. I am building a new system and using ez b to monitor salinity, nitrates and ammonia, temp , water current flow and the ph. The ADC ports are useful for these and EZ board can control the current and switching to a backup power supply ( a apc for computers inside the cabinet to keep ezb and pumps powered). Also the ezb can turn on and off night , morning , day , and evening lighting settings. With a custom injection device im designing ezb can provide nutrients , calcium and even medicine if levels are out of wack. I started the build today and I am very excited!
#105
also looking at you ROV design i am working on one with camera and special drive motor design and to motors to raise and lower the ROV,also belong to a yahoo ROV GROUP ,might look at posting the photos of it,was looking for a good microcontroller board and i think EZB is perfect,wouldnt fit inside any tank ,will post a new thread on the design
#106
@robotmaker thats a sediment filter ir removes solids. It doesn't add oxygen though or process nitrates. Does look like it can keep water clear of junk and poo floating around though.
Ok I picked up plexiglass from lowes and began measuring and cutting. In the entry way the tank has a three section bubble trap. The center section is where algae , live rock and the spaghetti (chato algae) the idea is to completly infest this area with bacteria and plant life to pull the nutritional solids like fish poop , decaying food an proteins.
my sister has one like it for over 4 years and no problems at all,thats the reason i am getting it can add another type to add oxygen also adding a lot of air stones release oxygen and adding plants but there is a machine if needed to turn salt into oxygen,my dad has one for his pool but airstones also the best i have the whole back wall line of stones ,like a wall of bubbles
#108
for nitrate removal you need a nitratereductor they are about $100 for 100 gallons another item i am getting is CO2 REACTOR ,ONE FOR MY FRESHWATER PLANTS and one for my saltwater tank ,petco has all theses types and more
#110
saw you video JOSH it does look good only its a very big setup on mine i am looking at professional setup it cost more but worth it and its a lot better it moves 900 gallons per hour compare to 360 gph on the electronics i might use the EZB, it is little over rated for this type of project ,but might use it because of the camera idea on adding a camera the EZ camera not ready the best camera the LUX is not great for darkness even with IR lights ,whats needed is .001 lux or so b&w camera to see darkness,i did see a very good ,color and switches to low lux B&W camera that may be better
#111
I tested the small pumps that will individually be pushing water through each canister. Still going very strong. Looks great.
#112
your design look good ,but with all the work on this project i guess you wont be able to finish you omnibot project
