KiwiRover
MPU9150 Polling Freezes PCA9685 Servos
Setup: Arduino Uno over USB to ARC running the Arduino EZB firmware, with an Adafruit PCA9685 16channel servo driver on the Arduino’s I2C (addr 0x40) driving 8 MG996R servos. Separate 5V/6A supply to servos, common ground tied to Arduino and PCA9685. I also have an MPU9150 IMU (addr 0x68) on the same I2C bus. In ARC I’m using the MPU9150 Accelerometer, Gyro, Temperature, Compass robot skill to read orientation and map roll/pitch to two servos. Variables look good in the Variable Watcher until things lock.
Symptom: With a script polling the MPU9150 every 100 ms using ControlCommand("MPU9150", "RunOnce"), after 20-90 seconds all servos on the PCA9685 freeze and the EZB connection becomes unresponsive until I reset the Arduino. If I stop polling the IMU, the PCA9685 runs for hours. Slowing to 500 ms extends the time but it still eventually freezes.
What I tried:
- Verified I2C addresses: PCA9685 0x40, MPU9150 0x68, no conflicts.
- Shortened SDA/SCL leads to ~20 cm and added 4.7k pullups to 5V (also tried 2.2k).
- Ensured solid 5V servo supply and GND common to Arduino/PCA9685/IMU.
- Called Init once, then RunOnce as documented; also tried pausing Auto Position during reads.
- Removed the IMU: no freezes; left IMU connected but no RunOnce calls: no freezes.
Minimal script causing the issue:
ControlCommand("MPU9150", "Init")
:loop
$roll = $mpu9150_roll
$pitch = $mpu9150_pitch
Servo(D0, 90 + ($roll*2))
Servo(D1, 90 + ($pitch*2))
Sleep(100)
Goto(loop)
Is this a known I2C blocking issue when using the MPU9150 skill alongside a PCA9685 via an Arduino running EZB firmware, and would migrating the servos to the PCA9685 servo Driver robot skill (recommended method) or reducing the EZB I2C clock be the right fix here?
Yes - this sounds much more like an I2C bus lock/blocking issue on the Arduino + EZB firmware side than a PCA9685 servo problem.
What your symptoms suggest
RunOncecallsThat pattern usually means the MPU9150 read is occasionally hanging the I2C bus or the firmware thread, and once that happens the PCA9685 updates stop too because they share the same controller/bus path.
Why this happens
On a shared I2C bus:
So even though the servo driver and IMU have different addresses, they still depend on the same I2C bus transaction flow.
Most likely fixes
1) Use the PCA9685 servo Driver robot skill instead of Arduino firmware I2C for servos
This is the recommended path now.
The big advantage is that ARC manages the PCA9685 through the skill layer, which tends to behave better than mixing multiple I2C devices through older firmware paths.
https://synthiam.com/Support/Skills/Servo/PCA9685-Servo-Driver?id=23154
If your servos are on the PCA9685, I’d strongly recommend moving them to that skill and keeping the IMU separate in how it’s polled/handled.
2) Lower the I2C clock speed
If the IMU and PCA9685 must share the same bus, reducing I2C speed can improve reliability.
In ARC, the I2C clock can be set through script:
You can also try:
If the bus is marginal, slower is often more stable.
3) Poll less aggressively and avoid tight loops
Your 100 ms loop is reasonable, but if the device occasionally stalls, frequent reads increase the chance of hitting the failure window.
Try:
4) Rework the logic so servo updates don’t depend directly on every IMU read
Instead of reading IMU and commanding servos in one tight loop, split responsibilities:
That can help reduce I2C pressure.
Important note about your current script
This part is suspicious:
If these servos are actually on the PCA9685, they should usually be virtual ports like
v0,v1, etc., notd0andd1, unless you truly have native servo outputs on the Arduino firmware ports.If those are PCA9685 channels, it should look more like:
That matters because the port type determines whether ARC is talking through the correct servo subsystem.
What I would test next
My recommendation
If this were my setup, I would:
That gives you the best chance of avoiding the bus lock.
Helpful links
https://synthiam.com/Products/ARC
If you want, I can help you rewrite that script for the PCA9685 skill using V0/V1 ports and show a safer architecture for the IMU polling loop.
