Good Morning,
I am looking for some help with a program or script that will parse an xml file and convert to txt so that ARC can read.
Thanks! Wayne
Vuzix Augmented Reality
— Connect Vuzix 920VR AR headset to ARC to map head movement to robot servos or drive, control camera pan/tilt; deprecated 920VR support only.
Good Morning,
Thanks! Wayne
Xml is a very dynamic format. Sure, it separates information into tags - but the number of tags and the type of information can vary soooooooooooo much that a simple "parser" is impossible without a context. Do you have an example xml file? And what is the objective?
Those two answers and it will be easy
You need an xslt function / library.
XML is far too dynamic for a simple EZ-Script library - specifically due to the limited use cases. It makes more sense for a plugin to be created for the xml file in question.
