Virtual Reality Robot icon Virtual Reality Robot — Stream robot camera to VR and control servos with headset pitch/yaw; supports SteamVR and Cardboard (iOS/Android) for immersive teleoperation Try it →
Resolved Resolved by Athena!
Linking Opposite Rotating Servos
, i built an robot arm, the shoulder rotates using 2 servos connected on port D0 and D1 on an iotiny. Both servos are mirrored. it means when D0 rotates CW ,D1 must rotates CCW to have the arm moves in the same direction. I made a test using the skills horizontal servo with advanced mode. D0 is the master D1 is the "slave" and i checked invert. It works fine, both servos rotates in the opposite direction. D0 rotates CW, D1 rotates CCW.  I'd like to use auto-position skill. I created an image, i added 2 servos D0 and D1. I can control each servo individually. Is it a way to "link" both servos ? When the servo D0 rotates, the servo D1 must rotate in the opposite direction.
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Relative Servos by Synthiam
Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control
Hi jp15sil24,
You're absolutely correct. When you need to control a large number of servos (like 30), using the global ARC commands is a more scalable approach. You can set the global limits for each servo using commands like:
SetServoMin(d0, 60);
SetServoMax(d0, 170);
For each servo, just repeat these commands with the appropriate port (e.g., d1, d2, ..., d29). This way, no matter which skill sends the servo commands, the global limits will be enforced.
Let me know if you need further clarification or additional help with your ARC project!
