Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
OK, I have sorted it out. I just needed to step back, have a coffee and then have another go (see how easy it is to blame the device when it was user error?).
The commands are;
CL = Clear Screen CS0 = Turn Off Cursor CS1 = Turn On Cursor BL0 = Turn Off Backlight BL1 = Turn On Backlight TP,x,y = Position Text. Example SendSerial(D14,9600,TP,3,1) - Top left = 0,0 bottom right = 15,1 TT = Text Entry 0 = Exit modes.
Quick Example, I will work on more now;
# LCD Script Examples
# Baud 9600
# Port D14
# Clear the screen and turn off the cursor and position top left
SendSerial(D14,9600,CL)
SendSerial(D14,9600,CS0)
Sleep(100)
# Display welcome message
SendSerial(D14,9600,TP,5,0)
SendSerial(D14,9600,TT)
SendSerial(D14,9600,"MELVIN")
SendSerial(D14,9600,0)
SendSerial(D14,9600,TP,4,1)
SendSerial(D14,9600,"START UP")
Sleep(3000)
# Clear The Screen
Sleep(100)
# Position Some Text
SendSerial(D14,9600,TP,0,0)
SendSerial(D14,9600,"SAMPLE1")
Sleep(100)
SendSerial(D14,9600,TP,0,1)
SendSerial(D14,9600,"SAMPLE2")
Sleep(100)
Sleep(3000)
# Clear The Screen
Sleep(100)
# Animate Some Text
$posx = 0
:loop
SendSerial(D14,9600,TP,$posx,0)
SendSerial(D14,9600,"*")
IF($posx<16)
  $posx=$posx+1
  Sleep(100)
  Goto(loop)
EndIf
Another example of how to make it do it's thing is;
SendSerial(D14,9600,CL,TP,2,0,TT,"Hello World",0)
That way saves having to write out all of the SendSerial lines.
OK, spent the best part of today playing with this display and figured it all out now.
Positioning of text is simple when you think about it (I think I may have been getting mixed up on the X and Y)
However, one thing I've noticed and I hope someone can point me in the right direction or explain it is this...
If a servo is being held and SendSerial is executed the servo will twitch. Not every time but a lot of the time. I have my test bot displaying the current ping along with the current time on the display, updated every 500ms. The sweep servo is held at 20 but twitches every second or so.
Is it the display causing this or is it a general occurrence?
That is the same one, same auction, same everything.
Simple to wire up
EZB     LCD     Colour
VCC     VCC     Red
GND     GND     Black
SIG     RX      White
Then plug it in to a digital port on the EZB
Excuse the poor quality it was taken quickly
Just make sure it comes with an LCD, that picture is of just the "backpack" (or LCD driver)
Example Script #1 (yes there will be more)
# Time Date
$baud=9600
$port=D14
SendSerial($port,$baud,CL,CS0,TP,0,0)
Sleep(100)
SendSerial($port,$baud,TP,3,0,TT,"EZ-Builder",0)
Sleep(500)
SendSerial($port,$baud,TP,3,1,TT,"Connected",0)
Sleep(1500)
# Time and Date
SendSerial($port,$baud,CL,TP,1,0,TT,"Time and Date",0)
Sleep(1500)
SendSerial($port,$baud,CL,TP,0,0,0)
# Display Time on Line 1
:loop
SendSerial($port,$baud,TP,6,0,TT,":",0)
# Format the time
# Convert to 12 hour
IF ($hour>12)
  $timehour=$hour-12
  SendSerial($port,$baud,TP,10,0,TT,"PM",0)
ELSE
  IF ($hour=0)
    $timehour=12
  ENDIF
  SendSerial($port,$baud,TP,10,0,TT,"AM",0)
ENDIF
IF (Length($timehour)=1)
  SendSerial($port,$baud,TP,4,0,TT," ",0)
  SendSerial($port,$baud,TP,5,0,TT,"$timehour",0)
ELSE
  SendSerial($port,$baud,TP,4,0,TT,"$timehour",0)
ENDIF
IF ($minute<10)
  SendSerial($port,$baud,TP,7,0,TT,"0",0)
  SendSerial($port,$baud,TP,8,0,TT,"$minute",0)
ELSE
  SendSerial($port,$baud,TP,7,0,TT,"$minute",0)
ENDIF
# Display Date on Line 2
# Format Date UK Style
IF ($day<10)
  SendSerial($port,$baud,TP,3,1,TT,"0$day/",0)
ELSE
  SendSerial($port,$baud,TP,3,1,TT,"$day/",0)
ENDIF
IF ($month<10)
  SendSerial($port,$baud,TT,"0$month/",0)
ELSE
  SendSerial($port,$baud,TT,"$month/",0)
ENDIF
SendSerial($port,$baud,TT,"$year",0)
WaitForChange($second)
SendSerial($port,$baud,TP,6,0,TT," ",0)
Goto(loop)
There may be a better way to format the time & date, I haven't spent long looking in to that but the above way works. It also updates every second with a blinking . which could be changed for every minute if it is eating up the communications.
As always, easy to change for your LCD, port and baud are variables at the top of the script.
As much for reference in to doing anything than as an example for making a clock.
Edit: Minor bug fix made to hour when changing to single digit would have left the leading 1.
#16
All code I post will work:)
