Wii Remote icon Wii Remote — Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking. Try it →
Laptop Recommendation?
I'd like to put all my robotics on a dedicated laptop. I don't think I need a cutting-edge machine, but I feel I need something with a good processor to handle multitasking.
I'd prefer something with a 10" -13" screen (my other machines are 17" monsters), Windows 10 upgradable (if it doesn't come installed), a nice large hard drive and something I can tear down and upgrade if I want (no glue-sealed cases!). No Chromebooks; all my data and files stay with me, not in the cloud.
It doesn't need to be new. Reliability a must! Price range < $300. (Good grief! I feel like I'm placing a dating ad!:P )
What are you guys using? Any recommendations?
They do sell appliances though, but I had a lot of parts laying around, so I used them instead of buying an appliance.
@CochranRobotics -
Thanks for the info on NextCloud. Despite my distrust of the cloud, NextCloud appears to be a safer and more private way than port forwarding to access my files remotely. Especially since port forwarding is above my comprehension level, and I'm sure I'd set it so my server was public rather than private.:)
Now, that brings us back to what a good, cheap, robust laptop (10" - 13") might be good for my robotics work. While I'm not afraid to go under the hood to make modifications, I'd just as soon not have to replace a motherboard, etc. Guess I'm looking for instant gratification.;)
One more thing on the NAS RAID setup.
In the hardware physical configuration, it is important to make sure that the sata controllers are not all setup to go to the same drive in each set. This is because if you have drive 1 from each set going to a sata controller, and your controller goes down, you will need to perform a recovery that is more extensive.
There are two decent options.
Option 1... Controller 1 disk 0 set 0 disk 1 set 0 disk 2 set 0 disk 3 set 0 If the sata controller goes out, you will loose the raid 10 but because it is mirrored, you will be able to recover and be able to run in a degradated mode until the issue is resolved.
Option 2... Controller 1 disk 0 set 0 disk 1 set 1 disk 2 set 2 disk 3 set 3 If the sata controller goes out, you will still be able to recover due to the redundancy built in and may not be able to run in a degradated mode very well, but it should work.
bad configuration controller 1 disk 0 set 0 disk 0 set 1 disk 0 set 2 disk 0 set 3 If the sata controller goes out, you will have a downed environment that will need hardware replacement and then a recovery. Don't do this. It will probably require you to do a resilver and then a restore from backup.
I opted for option 1 as it still leaves 3 copies of the data available to use and still provides a raid 10 config for redundancy until the controller is replaced. I simply run in a degradated mode until I can do this repair, and the external drive is still able to be used for backups.
Thanks much! I'm on the trail!
