JD Humanoid Won't Turn On
Good day fellas,
Our lab just purchased a JD humanoid. However, when we try to switch on, this is nothing happened. There is no light and no sound. We checked the battery which can be charged and it was fully charged at that time.
We are trying to find the solution to it, wish someone here can provide us with some support. Thank you in advance!
Does anyone have any idea?
JD Humanoid by EZ-Robot
JD humanoid robot kit - WiFi-enabled, 16 DOF with metal-gear servos; easy, fun, educational, available from the EZ-Robot online store.
Tutorial by mikebmac
Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images
you need to go to ... www.ez-robot.com They are the makers of that product. They will be able to help you there.
did you check the fuse?
