I've Started To Work On Mapping Using The Vx-11 Lidar
The boards have been pretty quiet so I thought I would share what I am working on now.
This is for robots using an on-board computer I have started making a plugin that is designed to use the xv-11 sensor, wheel radius and encoder counts per revolution of the wheels to make a map of the environment. It also uses the compass part of the 4-in-1 sensor sold on this site.
The map is currently stored in a SQLLite3 database. It is housed in the plugin directory. I don't know if this will be the final design or not but it is what I have working right now. There is a map table that is created by the user with the plugin. It contains the X coord, Y coord, tile and Counter fields. This will be used to store the map as it is being updated. The tile will be marked when the LIDAR recognizes something in that location of a certain intensity.
Quote:
The tile size is determined by the wheel diameter. If you have small wheels, you have small tiles. If you have large wheels, you have large tiles. The current environment that I am testing in has tiles that are about 4.19 inches by 4.19 inches. This is because I have wheels that are 4 inches in diameter and if you take the wheel diameter * pi / 3, you come up with 4.188790266.... I round this to 2 decimal places. If you had wheels that were 2 inches in diameter, you would have tiles that are 2.09 inches. If you had wheels that were 12 inches in diameter, the tiles would be 12.57 inches. The logic is that the wheels would be much smaller for robots in smaller environments and much larger for robots in larger environments. Larger wheels means faster moving robots and thus the updating of the environment would have to account for faster moving robots. The number of tiles in the map is determined by the configuration screen by setting the size you want your map to be. In the test, the map is 50 feet x 50 feet. Using a robot with 12 inch diameter wheels indoors in a 50x50 foot house could become problematic. These are all subject to change depending on testing.
Well the information quoted above has changed. I am in the US and as such am more comfortable using inches and feet, so I am making 1 inch tiles for everything. The wheel diameter is still important but not as important in laying out the grid. I am converting the mm readings from the LIDAR to inches and marking the squares. We will see how this works out and go from there. This, along with everything else is subject to change as I go through it all.
The map on the screen is loaded from the SQLLite3 database initially. As things are seen by the LIDAR, the map table is updated and the display is updated by marking the corresponding tile on the map.
Eventually my goal is to take this logic and use it in SLAM. I plan on starting with some simple SLAM using the RANSAC algorithm which is best used in indoor environments. This is because it estimates and creates landmarks based on straight lines. From there I will use the Extended Kalman Filter for data association. This allows the robot to recognize landmarks and then adjust its current position on the map based on these landmarks.
One of the reasons that I want to store this information in a SQLLite3 database is that this would allow me to have multiple maps housed in different tables. The configuration screen could be modified to allow the user to specify which environment the robot is in (office 1, Office 2, home, Mom's house for example). These maps would be stored in different tables and the user would just switch to the map that pertains to the current environment. Another thing that these multiple maps could be used for is to handle different floors of an office building, one for each floor.
The test map is about 13 meg in size. This isn't too large but is only based on a 50x50 foot house on a robot with 4 inch diameter wheels. If you were in a warehouse or large office building with a robot with small wheels, the size of the database could get really large I would imagine. The goal is to get this to work in a smaller environment, and then see what needs to be done to handle larger environments.
Eventually, I plan on incorporating a path finding algorithm. This shouldn't be too hard to do because it is done in video games like crazy. There is plenty of sample code to build from.
Anyway, that is what I am working on currently. I suspect it will take some time before I have something to share. This is a pretty ambitious project and I will post updates as I accomplish different things with it.
I am not sure if I will sell this plugin or make it freely available. This is something that I will decide after I know how it works in multiple environments. If it turns out to be simply amazing, I might sell it. If it just works, I will give it away for free and continue working on a final solution.
#41
Sweet! Thanks David. Who out there is working on a cloning machine Haha
#42
@d.cochran,
I made a script to use your Lidar plugin and was hoping there is a way to shorten it, example.. [code} $LIDARclose =800 # Change for minimum distance
#Lidardistance[] Base Right $LIDARDistance[0] $LIDARDistance[1] $LIDARDistance[2] thru $LIDARDistance[80]
#Lidardistance[] Base Left $LIDARDistance[354] $LIDARDistance[353] Thru #$LIDARDistance[269]
#Right side lidar if($LIDARDistance[0] < $LIDARclose or $LIDARDistance[1] < $LIDARclose or ..... and $LIDARDistance[325]> $LIDARclose and $LIDARDistance[324]> $LIDARclose and $LIDARDistance[323]> $LIDARclose and $LIDARDistance[222]> $LIDARclose and $LIDARDistance[321]> $LIDARclose) goto(Left) sleep(3000)
My current script has every variable set in the script, $LIDARDistance[0]
$LIDARDistance[1]
 etc.. ; is there a way to define a range, eg, $LIDARDistance[0] thur  $LIDARDistance[359] ?
Hope this post makes sense.
Thanks
#43
Hey Mike,
Sorry, I just saw this. I have been really busy lately. I won't have time until maybe tomorrow night to look at this. I have to go to Dallas this evening to make sure that a data center move for this weekend is planned well. This weekend will be busy with this move. I should have time tomorrow night to look at it depending on some other things, but will do my best to look into how you could make the script shorter.
Thanks for understanding.
David
#44
Thanks David, no rush I was hoping to not have to define each Lidar degree variable, the full script I have with each variable takes about 500 ms to run through the the script.
Thank again, Mike
#45
Hey Mike,
Without writing everything up for you, I wanted to give you the direction that I would go...
The gist is that you would use a variable that would be updated as you cycle through the array variable to get and evaluate the values from the LIDAR. When you get to 360, you drop out. You could also evaluate the other values returned from the LIDAR to judge how reflective the item is at those degrees.
YOU WOULD ONLY DO THIS PART AS A TEST
DefineArray( $test, 360)
$ArrayPossition=0
:TheLoop
  THIS IS WHERE YOU WOULD PUT IN YOUR RANGES
  if($ArrayPossition > 10)
    if($ArrayPossition < 50 )
      THIS IS WHERE YOUR LOGIC WOULD GO TO DO SOMETHING WITH THE VALUE FROM THE LIDAR
      if($test[$ArrayPossition] <25)
          say("There is something close to me at " + $ArrayPossition + " Degrees")
          endif
     endif
endif
CHECK TO SEE IF YOU ARE THROUGH ALL DEGREES
if($ArrayPossition > 360)
  IF SO, GET OUT
     goto(OUT)
endif
goto(TheLoop)
:OUT
This isn't tested code as I am on a linux laptop right now, but it should be close to working. Remove the comments and you should be close to a solution.
#46
I connected the GetSurreal.com Lidar and Teensy to a Raspberry Pi 3 Model B.
I installed vpython (with some help from the vpython forum as it is not 100% easy) and pyserial (in fact already installed), ran the visual python 3D script from GetSurreal, and hey presto I have portable lidar.
I might get the Raspberry to talk to my EZB at some point which would be a neat additional thing to do.
You need a Raspberry Pi 3 to do this and earlier Raspberry models will not work.
I think this is a good alternative to the impressive and really easy to use ez-robot plugin which is described in this thread as there is no need for a pc.
Cheers
Chris
#47
I dont use the Pi but it is an option. I connect it directly to the tablet that is a part of my robot. The EZ-B V5 will take care of the need for an additional computer when it comes out.
#48
Hi There
Just to finish off my comment. I found a way to put teamviewer on the raspberry pi and so now I have remote access from my master pc to the 3D neato lidar output on my raspberry .
As noted this could perhaps more easily be done with a compact PC but my way is probably a bit cheaper ...
This is what you do:
  1. use a raspberry 3 pi model b (or better) or vpython will not run
  2. use a large SD card in your raspberry as the software is large in size. I used a 32GB card after smaller ones were not big enough.
  3. use raspi-config in terminal to enable the experimental GL Driver graphics
  4. install vpython (sudo apt-get install python-visual)
  5. install exagear (which costs money) and teamviewer following these instructions: https://eltechs.com/run-teamviewer-on-raspberry-pi/
  6. Download lidar.py from: https://www.getsurreal.com/products/xv-lidar-controller/xv-lidar-controller-visual-test
  7. Identify the correct com port for the teensy and edit lidar.py
  8. run python lidar.py from terminal
  9. use teamviewer and enjoy lidar graphics on your master pc
Let me know if you have any problems but once you know the pitfalls it really is quite easy (ha!)
Cheers
Chris
