EZ-SLAM icon EZ-SLAM — Creates a map in a global variable; proof-of-concept SLAM visualizer (very experimental). Try it →
Is There A Trick To Getting A The Blue Tooth To See A Second Ez-B Controller?
My first EZ-B controller works well, but is dedicated to a robot. I bought a second EZ-B controller to start another project, but cannot get the blue tooth to recognize the new controller.
Note that I just used the first controller and disconected power before trying to recognize the second controller.
Thanks
Add the second controller to your computer the same way the first controller.:) the Tutorial section will help you, specifically this page: https://synthiam.com/Tutorials/Default.aspx?id=5
Also, you can rename the Bluetooth name of the EZ-B by adding the CONFIGURATION control. Add Controls -> Configuration
Can you use configuration to change the camera name too?
No. There is currently no simple way to change the name of the camera, the only way I found was to modify the registry which can be very risky and is not recommended.
